Home > Technical > black on wheels
djsaad1
United States 2006 Range Rover Sport Supercharged Java Black
black on wheels
My wheels get black stuff on them pretty fast. I got a car wash yesterday and today my front wheel already has black stuff all over it. What is this stuff is it coming from the break pads? Is anyone else noticing it? Its pretty hard to keep the wheels clean
Post #6983 Mon Dec 05 2005 10:38pm
Rob_J
Location: Usually flat out on the sofa with glass of vino
England 2005 Range Rover Sport TDV6 HSE Java Black
That'll be brake dust. No stopping it I'm afraid. It's always worse on the fronts. You can get cleaners that get it off quite quickly. You can also get coatings that make it easier to remove. It's worthwhile cleaning off frequently as it can get very difficult to remove if it's left on too long. If you've time it's also good to remove the wheels every so often & do the inside of the rims too. You'd be amazed at how much better the wheels look. This also gives you the chance to give the wheel arches a real good clean. HSE TD6 (Java Black/Ivory)
911GT3 (Guards Red, carbon interior)
ElanSE (BRG)
Panamera Turbo S
Boxster S
Post #6992 Tue Dec 06 2005 8:32am
Not sure how many of these you will be able to get in the US, but Auto Express did a test of wheel cleaners...
http://www.autoexpress.co.uk/product_test/...ishes.html
..some with brake dust repellents.
Post #7019 Tue Dec 06 2005 12:05pm
djsaad1
Thats odd, I have never had anything like this before on my other cars. But then again all my other cars have been lexus. Is there anything I can do, like get a different type of break pad or something?
Post #7041 Tue Dec 06 2005 3:42pm
Tim in Scotland
I hardly get any dust on my TDv6SE even when it gets driven quite hard. The last RR and the Freelander I ran there was always a lot of brake dust on the front wheels even after a short drive. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #7045 Tue Dec 06 2005 3:55pm
djsaad1
maybe it has something to do with the brembo brakes on the supercharged?
Post #7047 Tue Dec 06 2005 3:56pm
Coffeeman
United States
Replace the pads with Axxis pads from Australia. Almost zero dust.
Post #7460 Thu Dec 08 2005 7:45pm
stwsam
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
dirty wheels
if you use tire black, spray your wheels with a window cleaner and wipe absolutely dry. Tire spray helps brake dust stick like glue. With properly cleaned wheels, a mile soap on cool wheels will allow 95% of your dirt to be hosed away!
Post #9869 Tue Jan 10 2006 3:27am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Yes, Tyre dressings attract the dust. As the wheels spin the vortices sucks in air , pulling the tyre dressing onto the alloy wheel, where the dust then settles and bakes on.
I always give my alloys a coat of good wax to keep them cleaner, makes them easier to clean off and also prevents build up and long term brake dust damage.
Beware of some wheel cleaners being FAR too acidic and eating away at the lacquer coating though, especially if the wheel is damaged or scratched as it will get under ther surface and cause havoc. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #9956 Tue Jan 10 2006 4:20pm
