![]() | Home > General > Fitting Brembos to my 3.6 TDV8 |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
Finally got round to painting. Etch primer and then a few coats of satin black. Brembo stickers arrived today and applied and then off to the paint man to lacquer when he tidys up my bumper on Monday.
NoExpert Member Since: 28 Jan 2022 Location: PoznaĆ, Poland Posts: 493 ![]() ![]() ![]() |
Looking good.
grey17 Member Since: 18 Jul 2016 Location: Devon Posts: 68 ![]() ![]() ![]() |
Hi everyone.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
The six pot calipers are all the same, L405/494 will fit the L320, you will however need the 380mm dia. discs. The SVR 6 pots did have a extra couple of holes/threads on them to bolt a ridiculously expensive carbon fibre shield on them.
Thanks Col, much obliged! Whilst here, do the 6 pot Brembo equipped L320 have the same standard rear calipers as all the rest?
I can't be certain, but I think the rear calipers are the same on all the 10/13 L320's, but on the S/C the carriers are slightly different as the S/C has slightly larger diam. rear discs. The L494 etc. are totally different rear calipers and won't fit a L320.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4442 ![]() ![]() ![]() |
The only L320's with factory 6 pots were 5.0 SC
[I can't be certain, but I think the rear calipers are the same on all the 10/13 L320's, but on the S/C the carriers are slightly different as the S/C has slightly larger diam. rear discs. The L494 etc. are totally different rear calipers and won't fit a L320.
[quote="Disco_Mikey"]The only L320's with factory 6 pots were 5.0 SC
