Home > Maintenance & Modifications > L320 auto box service, sump change? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
Metal sumps leak for fun. They are usually fitted by someone incapable of fitting the OEM plastic sump |
Mon Feb 03 2025 9:26pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9010 |
Is it worth changing the sump? A full flush gets the dirty oil out and replaces it all with nice fresh stuff. Does changing the filter make much difference? Does changing the filter and half the oil do a better job than just changing all of the oil? 2012 SDV6 - it's missing a couple of cylinders
Mon Feb 03 2025 9:53pm |
phazed Member Since: 02 Feb 2025 Location: Dorking Posts: 8 |
Are you saying that it probably best to take it to a specialist to flush and fill? |
Tue Feb 04 2025 9:51am |
That has been the perceived wisdom around here and the Discovery sister site for some time. Some still like the idea of changing the filter. I've had both options done over the years and these days I just get the oil flushed every 3 years. 2012 SDV6 - it's missing a couple of cylinders
Tue Feb 04 2025 10:08am |
Just noticed that a garage that I have used for MOT’s a few miles from me specialises in flushing and renewing fluid in Auto boxes. I have just spoken to them and they are emailing me an estimate today. They said all the fluid is 100% changed and it will have a new filter fitted. I am expecting a reasonably large figure!
Tue Feb 04 2025 10:16am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5007 |
metal sumps do tend to leak.
Tue Feb 04 2025 11:46am |
From memory, the metal sumps are BMW items. Not sure why they should be more prone to leaks if correctly installed, but Disco_Mikey works on these vehicles for a living so he'd have seen plenty of them over the years. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Feb 04 2025 12:12pm |
design
Tue Feb 04 2025 5:52pm |
Just had a quote of £600 to fit a new metal sump, filter and flush and change the oil on the box from a known reputable garage.
Tue Feb 04 2025 6:05pm |
There are ways to change almost all of the oil.
Tue Feb 04 2025 7:43pm |
