Home > Maintenance & Modifications > How To - AMK Suspension Compressor Replacement
liverpool_luke
Lost for Words wrote:
There are two software versions for the AMK - 9H22-5A919-AA and 9H2M-5A919-AA. Thumbs Up
This is great information and exactly what I needed but could not find anywhere online thank you!
Post #481689 Sat Dec 05 2015 10:25am
liverpool_luke
Disco_Mikey wrote:
And they are specific between ARC/non-ARC Thumbs Up
When the Indy did the update with autocom (assuming this is capable?) He did ask does the car have blah bla blah (mutter English couldn't hear him) he poped the bonnet and said no you don't have it, wonder if he referred to arc ? What is it how would I tell I have it? With thabks
Post #481690 Sat Dec 05 2015 10:27am
liverpool_luke
won't mention any names, went back to the garage that was paid to update the firmware (knowing that the firmware install was only 6XXX) spoke to the guy who said you sure I updated it as I don't remember putting a battery charger on last time !
I then asked whet I have paid �50 for when I went in and only ever asked for the air compressor firmware update
so an hour later I drive away with NOT ONE error in the system on a global read with firmware version 9H32-14D394-AA
updated using autologic (not autocom as list above) no lights on the dash
advised my friend now it's all working fine sell the bloody thing ! Laughing
Post #481974 Tue Dec 08 2015 8:54pm
Joser
2006 Range Rover Sport Supercharged Bonatti Grey
What did you do with this piece
Post #487750 Wed Feb 17 2016 2:14am
liverpool_luke
For better or worse I didn't use that bit or cut the pipe, didn't feel comfortable cutting them, I left them.the original length and placed them so there was no kinks anywhere
Post #487763 Wed Feb 17 2016 8:57am
Joser
Ok cool thanks for the info this thread has helped me alot
Post #487788 Wed Feb 17 2016 1:36pm
Daztrex700
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
After installing new pump do you need to clean out the 4 air valves for each corner of the car? Don't know the name of them. Thanks
Post #513774 Sat Jan 07 2017 1:05pm
Daztrex700
My RRS
Post #513775 Sat Jan 07 2017 1:09pm
Joser
Are you referring to the valve blocks? If so im pretty sure the are only three when i replaced my pump i did not do it.
Post #513817 Sat Jan 07 2017 9:44pm
Daztrex700
Yes that's it thanks
Post #513821 Sat Jan 07 2017 10:05pm
Daztrex700
Still do not know where and how the four brass inserts fit or go. two 8mm and two 10mm brass tubes i take it one brass tube each side of the air connector? what do the brass tubes do?
Post #559243 Sun Jun 17 2018 11:06pm
Daztrex700
i think this is the best way to fit?
Post #559311 Mon Jun 18 2018 9:48pm
Daztrex700
or like this?
Post #559319 Mon Jun 18 2018 10:37pm
Chrispiec
Hi guys,
I replaced my amk compressor today with a new aftermarket one but now I am getting suspension fault and unable to do anything with air suspension or the terrain selections. Getting code c1a36 exhaust valve. Could this mean I need the updated software rather than anything actually being wrong with my install or the new compressor.
Post #565932 Thu Sep 27 2018 10:30pm
PatM
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
I had my 08 L320 in for diagnostic and repair, just before xmas '24. They replaced the compressor and re-flashed the ECU. Problem gone- no amber light and 'special programs' fault.
However, my new compressor runs each time I start the car for a minute or so- yet the suspension doesn't seem to drop at all?
My logic is telling me that if it has a slight leak, then its likely to be the air reservoir tank?- otherwise the car would drop one side or something?
Does anyone have a suggestion of do I just put up with it? My new compressor is much louder than the old Hitachi one...The iNDY said that they wouldn't fit the 'Amazon or easy ones' as they always fail, so Im presuming its an AMK that was fitted- hence the re-flash.
Post #646449 Thu Jan 23 2025 12:54pm
