![]() | Home > Maintenance & Modifications > How To - AMK Suspension Compressor Replacement |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4460 ![]() ![]() ![]() |
I don't know if this will be of any interest to anyone over here, but I posted it up over on Disco3 (http://www.disco3.co.uk/forum/topic84165.html). It is (if you have not guessed already) a guide to replace the air suspension compressor, with the new style AMK compressor. It was fitted to a Disco 3, but the procedure is exactly the same for the RRS. Enjoy |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Great write up disco mikey
IIRC, the new one is cheaper than the old one |
Nice one.
Nice one.
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 ![]() ![]() ![]() |
Hi All,
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Just posting this SSM for reference regarding replacement of compressor from Hitachi to AMK:
Also, for the... 3 of us with Rover Specialties rock sliders on their Sport (but the same issue may affect Disco3/4 owners), or owners with similar rock sliders extending under the chassis to protect the compressor, be aware that the new bracket of the AMK unit hangs a bit lower than the old design. The bracket may interfere when attempting to re-fit the sliders after replacement, even with the lower plastic cover removed. My 2013 LR4 is currently being fitted for Tactical 4x4 rock sliders (similar to the Rover Specialties') and the company is manufacturing a slightly modified bracket for the AMK compressor, made of thinner steel, which will allow the compressor to sit a bit higher within the upper cover and eliminate the issue. Here is a photo of the original bracket, and template of the modified one they are fabricating for me (and for other owners of their sliders with the new compressor fitted): Original bracket:
Modified bracket (template only):
olikk23 Member Since: 08 Jul 2014 Location: Manchester Posts: 1 ![]() ![]() ![]() |
Hi,
liverpool_luke Member Since: 03 Nov 2015 Location: Liverpool Posts: 7 ![]() ![]() |
I'm sorry to add to an old thred just wanted to ask a question regarding the software update for this, I am going to replace a friend's compressor tomorrow for this newer one following the thred, can I update the software with a hawked at all ? |
I don't believe the Hawkeye is capable of any reflashing |
Anyone around Liverpool area that can update it for me?
Supposedly had the software updated by small Indy garage , I have now changed the compressor twice and still the same fault, can anyone adivce what the software number should be? |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
There are two software versions for the AMK - 9H22-5A919-AA and 9H2M-5A919-AA. |
And they are specific between ARC/non-ARC |
