![]() | Home > Maintenance & Modifications > How To - AMK Suspension Compressor Replacement |
liverpool_luke Member Since: 03 Nov 2015 Location: Liverpool Posts: 7 ![]() ![]() |
When the Indy did the update with autocom (assuming this is capable?) He did ask does the car have blah bla blah (mutter English couldn't hear him) he poped the bonnet and said no you don't have it, wonder if he referred to arc ? What is it how would I tell I have it? With thabks |
won't mention any names, went back to the garage that was paid to update the firmware (knowing that the firmware install was only 6XXX) spoke to the guy who said you sure I updated it as I don't remember putting a battery charger on last time !
Joser Member Since: 17 Feb 2016 Location: California Posts: 3 ![]() ![]() |
For better or worse I didn't use that bit or cut the pipe, didn't feel comfortable cutting them, I left them.the original length and placed them so there was no kinks anywhere |
Ok cool thanks for the info this thread has helped me alot |
Daztrex700 Member Since: 07 Jan 2017 Location: Telford Posts: 6 ![]() ![]() ![]() |
After installing new pump do you need to clean out the 4 air valves for each corner of the car? Don't know the name of them. Thanks |
Are you referring to the valve blocks? If so im pretty sure the are only three when i replaced my pump i did not do it. |
Yes that's it thanks |
Chrispiec Member Since: 23 Sep 2018 Location: Glasgow Posts: 3 ![]() ![]() |
Hi guys,
PatM Member Since: 02 Feb 2015 Location: Maidstone Posts: 8 ![]() ![]() ![]() |
I had my 08 L320 in for diagnostic and repair, just before xmas '24. They replaced the compressor and re-flashed the ECU. Problem gone- no amber light and 'special programs' fault.
