Home > General (L494) > horrible tapping noise, Running rough
Rob Evans
United Kingdom 2013 Range Rover Sport SDV6 HSE Bonatti Grey
Hi everyone. HELP PLEASE. My L494 Range Rover Sport was driving beautifully but i went through a pot hole and immediately it started a tapping noise from under the bonnet and i was only able to limp home. The next morning i went to the car, it started and ran great again . two weeks later, i was driving it when the dreaded red triangle appeared and i had to coast onto the side of the road. I limped home and the car was making terrible taping noise again . My Icarsoft computer came up with Fuel Injector driver fault. I cleared this but it still won't run properly. I fiddled with the wiring looms above the ECU and it wouldn't start at all. I cleared the faults again and it will now start but rough as hell and not drivable. ANY IDEAS PLEASE????
Post #646350 Sat Jan 18 2025 12:27pm
Nick900
Hi Rob,
Horrible when something like this happens. If the car is still showing a fault you need to read live data. I would suggest you start with injectors and fuel rail pressure. You should see [with the injectors] similar reading from all.
You could try checking the wiring at each injector but I would start with live data.
I think with Icarsoft you should also be able to run an actuation test which should tell you if the computer can activate each injector.
Nick
Post #646353 Sat Jan 18 2025 2:21pm
Disco_Mikey
Is this related to the injector seal issue you've just had?
Post #646354 Sat Jan 18 2025 2:53pm
Rob Evans
Hi Nick, thank you so much for taking the time to reply. It’s really appreciated. I will try all of the above . I have seen the actuation test but didn’t know what it was for . I will reply later and once again thank you
Post #646355 Sat Jan 18 2025 3:30pm
Rob Evans
Hi , I don't think there is a connection with the seal issue but who knows!!! lol
I suspect its an injector or injector control issue but difficult for me to narrow it down. Once again thanks for replying
Post #646357 Sat Jan 18 2025 5:04pm
Rob Evans
We have good news 🙏…I took all the engine covers off etc and disconnected all the wires to the injectors …carefully measured the resistance across the 3 injectors on the near side bank . I injector showed a much higher resistance across the coil and interestingly, occasionally to ground also .Luckily I had a spare ( secondhand ) injector which I fitted and all is ok now!!!! Thanks for your help guys and hope this helps someone else at some point🙏
Post #646387 Sun Jan 19 2025 8:50pm
