Home > General > Oil pump failure …. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4996 |
Sadly the 2007 models are very susceptible to this. So I wouldn’t doubt it.
Tue Dec 17 2024 8:14am |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 153 |
I had this many years ago on my 2007 L320, the cambelt tensioner lug snaps off the oil pump casting resulting in loss of cam timing. Mine required new pump, new cams (as the lobes had spun) and cam chains. All valves were OK as they tend to snap the camshaft cap bolts when the pistons contact the valves, so at least the heads didn't have to come off, just lots of cam cap bolts!
Tue Dec 17 2024 10:54am |
Billy82 Member Since: 25 Sep 2024 Location: Bolton Posts: 35 |
How susceptible are very early 2006 2.7 |
Tue Dec 17 2024 5:28pm |
Very! I'd get it changed as soon as possible or definitely if you have the cambelt changed. The general consensus is you're on borrowed time! |
Tue Dec 17 2024 5:30pm |
What are the symptoms. I thought very early ones were not susceptible to the. Is there a vin range |
Tue Dec 17 2024 5:35pm |
As far as I am aware all pumps up until MY2008 were of the weaker design. No real symptoms until it fails and you have piston to valve contact and a big bill to sort it out.
Tue Dec 17 2024 5:40pm |
I changed the cambelt myself and knew that some of them snap the casting when refitting as the bolts were too big. Oil pressure light goes off soon enough when starting. It was the original belt that was one when i changed it a couple of months ago |
Tue Dec 17 2024 5:47pm |
Boatman Member Since: 20 Dec 2018 Location: SOUTHAMPTON Posts: 14 |
AC-AD Weak casting / 13.5mm Rotor.
Wed Dec 18 2024 9:08pm |
Can you explain what you mean with this information |
Wed Dec 18 2024 9:09pm |
The oil pump casting has a number cast externally into it denoting its type with the two letters shown as a suffix. (See example). Therefore,when replacing with a new pump, the AB suffix with the 15mm rotor would be the one to fit. MY2006 / 2.7TDV6 HSE / CAIRNS BLUE |
Wed Dec 18 2024 9:21pm |
Where is this stamped |
Wed Dec 18 2024 9:22pm |
If you look on E/Bay for new Range Rover oil pumps- there are plenty of photos showing the casting number on the front face. MY2006 / 2.7TDV6 HSE / CAIRNS BLUE |
Wed Dec 18 2024 9:50pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 |
9X2Q-6600-AE
Thu Dec 19 2024 6:25am |
Thanks to No Expert for the updated info. My response was taken from my 'info archive', which I have now ammended. MY2006 / 2.7TDV6 HSE / CAIRNS BLUE |
Thu Dec 19 2024 9:01am |
