Home > General > Oil pump failure ….
harry_57
United Kingdom 2007 Range Rover Sport TDV6 SE Ipanema Sand
Oil pump failure ….
RRS TDV6 2.7 2007
Driving vehicle, oil light comes on, low gear mode selected message flashes up. Vehicle slows to a stop with transmission fault and engine management light on. Engine will attempt to start but won’t turn over. Car lifted and recovered to garage. Garage says it’s got an internal engine component failure. Most likely oil pump, but will most definitely need a rebuild. Thoughts please 😞. Owned car from new and always serviced annually.
Post #645823 Mon Dec 16 2024 11:15pm
Sadly the 2007 models are very susceptible to this. So I wouldn’t doubt it.
You may get away with an oil pump and some replacement heads.
Post #645824 Tue Dec 17 2024 8:14am
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
I had this many years ago on my 2007 L320, the cambelt tensioner lug snaps off the oil pump casting resulting in loss of cam timing. Mine required new pump, new cams (as the lobes had spun) and cam chains. All valves were OK as they tend to snap the camshaft cap bolts when the pistons contact the valves, so at least the heads didn't have to come off, just lots of cam cap bolts!
The pumps were upgraded several times, make sure you get the latest as they are a stronger improved casting but also displace more oil due to revised rotor thickness.
Post #645829 Tue Dec 17 2024 10:54am
Billy82
How susceptible are very early 2006 2.7
Post #645834 Tue Dec 17 2024 5:28pm
2 RRS
Very! I'd get it changed as soon as possible or definitely if you have the cambelt changed. The general consensus is you're on borrowed time!
Post #645835 Tue Dec 17 2024 5:30pm
Billy82
What are the symptoms. I thought very early ones were not susceptible to the. Is there a vin range
Post #645836 Tue Dec 17 2024 5:35pm
2 RRS
As far as I am aware all pumps up until MY2008 were of the weaker design. No real symptoms until it fails and you have piston to valve contact and a big bill to sort it out.
If it's the original pump it would certainly be a good idea to change it as it will definitely help oil pressure and hence engine longevity.
If the cars had a cambelt change before your ownership then it's possible a previous owner did it already. There are casting numbers that will identify at risk pumps/upgraded pumps. I'm sure I've seen them listed somewhere on here.
Post #645837 Tue Dec 17 2024 5:40pm
Billy82
I changed the cambelt myself and knew that some of them snap the casting when refitting as the bolts were too big. Oil pressure light goes off soon enough when starting. It was the original belt that was one when i changed it a couple of months ago
Post #645838 Tue Dec 17 2024 5:47pm
