Home > General > Intermittent None Starting - Hard Brake Pedal On Start Up |
RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 35 |
I had this myself.
Tue Jul 16 2024 7:33pm |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 164 |
Eh up Rallyesport
Mon Jul 22 2024 7:13pm |
Eh up all - update
Thu Aug 01 2024 8:18pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4401 |
Known issue. PCM+IPC software update, assuming you don't have a leaking servo |
Thu Aug 01 2024 9:02pm |
Eh up Disco-mikey
Fri Aug 02 2024 7:27pm |
A decent indy who has a genuine version of SDD can do the update |
Sat Aug 03 2024 5:31am |
Eh up
Sat Aug 03 2024 6:22am |
Hello again,
Thu Sep 12 2024 8:25pm |
Eh up Rallyesport
Fri Sep 13 2024 7:22pm |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 207 |
Hi, I just wondered if you got the update done and if it improved the issue. I only ask as I've noticed the past couple of weeks that mine has been doing exactly the same thing a couple of times. A rock hard brake pedal and then a click when I press start. It did it twice this mornig before successfully engaging the starter.
Tue Dec 10 2024 7:00am |
I still get the hard pedal on the odd occasion myself.
Tue Dec 10 2024 9:41am |
Eh up all,
Tue Dec 10 2024 8:07pm |
Thanks for your replies guy's, much appreciated.
Wed Dec 11 2024 6:01am |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 368 |
Check your battery connections. The 10mm bolt that held one of the secondary cables onto the main pos clamp needed nipping up. |
Wed Dec 11 2024 6:48am |
