Home > General > Intermittent None Starting - Hard Brake Pedal On Start Up
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Eh up all,
I’ve noticed more of late that when I jump in to start the car the brake pedal is hard, when I press the start button it simply does not start. I then repeat the process and press the brake pedal harder (really hard) and it always starts then ( or has done so far 🤔)
I had this once when I replaced all the discs n pads and put it down to that last year but now it’s a regular occurrence.
I might only manage to drive the car once a week as I work away.
I gather the car is waiting for a signal from the brake servo/abs to tell it your foots applied the brake and there is a pressure or brake pedal travel % calculation, without that confirmation it will not start.
When I drive it stop and restart - no problem at all, works every time 😁
I can only conclude some relationship between how I park it up and or the time between me using the car.
So I’ll try a couple of things, I park on a hill so tend to keep my foot on the brake, apply eps, put in park until switch off. I will now put in park, apply rob, take foot off brake and switch off to see if it makes a difference
I’ll also check again but no fault codes are logged relating to this and brakes are all perfect, I have no issues when driving.
I have also read it may be related to potential Vacum leak/loss - any tips on what and where to start looking are welcome
I’ve done some digging on this and there are a couple of old posts referenced but no conclusions drawn.
As always all help and suggestions are very welcome- if only to tell me not to worry too much 😁👍
Cheers all
Post #643131 Mon Jul 08 2024 8:47pm
RallyeSport
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
I had this myself.
I originally thought it was an issue with the gearbox not thinking it was in park.
But I see its a common issue on FF Range Rovers, Discovery's and RR Sports.
Like you, I can usually press the brake pedal enough for the switch to activate to allow a start.
I understand its vacuum related to the brake booster.
Mine hasn't done it for a little while, I've had the Sport for 2 months now and it happened twice now.
There's loads of advice online, seems a common issue.
Dean
Post #643313 Tue Jul 16 2024 7:33pm
TTR
Eh up Rallyesport
Thanks I’ll do some more digging, it’s not done it lately and it’s never not started it’s just odd when it occurs.
I’ll look more into the vac pipes and see if I can find their exact location and if there’s a common failure point.
All help welcome as usual 👍
Post #643409 Mon Jul 22 2024 7:13pm
TTR
Eh up all - update
Well it did it today with the Mrs 😂
Started though at third attempt, real mystery this as it’s definitely related to the brake pedal as I was away all the other week and ran it myself on Saturday
Parked it up , consciously put it in P then foot of brake then applied handbrake.
So it’s back to trying to figure out what’s causing this hic up.
With mine been an SDV6 would that make a difference - why should it 🤔
Anyone give me any pointers on the brake Vacum hoses to check.
I’ll try and have a look this weekend as home
Cheers in advance
Post #643553 Thu Aug 01 2024 8:18pm
Disco_Mikey
Known issue. PCM+IPC software update, assuming you don't have a leaking servo Thumbs Up
Post #643554 Thu Aug 01 2024 9:02pm
TTR
Eh up Disco-mikey
Read a lot about you on here 👍
Thanks for this - will look at the servo issue but great to know about the PCM and IPC software
Is it a dealer only job in that case 😤🤬
Will chase it down now I’m sure and I will update this thread
I’ve only come across rallyesport who’s commented so I was thinking it’s quiet unique 😁
Cheers again 👍
Post #643558 Fri Aug 02 2024 7:27pm
Disco_Mikey
A decent indy who has a genuine version of SDD can do the update Thumbs Up
Post #643565 Sat Aug 03 2024 5:31am
TTR
Eh up
Will update once I get further on
Thanks all
Post #643566 Sat Aug 03 2024 6:22am
RallyeSport
Hello again,
Id be interested in updates for this.
Thing is it would be putting a price on the SDD update from an independent dealer.
Money for old rope, I'm not being cynical, its just finding someone who can provide the update Disco Mikey is on about, I'd also like to think I could update other modules aswell, as I believe the last time mine was at a official LR dealer was a while ago, and they would necessarily do an update, only if the customer asks.
Dean
Post #644216 Thu Sep 12 2024 8:25pm
TTR
Eh up Rallyesport
I’ve went to see a local Indy I trust and he’s looking into this for me and thinks he can sort
I’ve been working away through most of Aug n September but back in a week
I’ll have time to catch up with him and I’ll report back
I always close out my threads as it really helps others - I know because this forums and its members have been a great help to me 👍
Typical the wife’s been using the car ad-hoc and it’s never repeated 🤔
Will update cheers all
Post #644228 Fri Sep 13 2024 7:22pm
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi, I just wondered if you got the update done and if it improved the issue. I only ask as I've noticed the past couple of weeks that mine has been doing exactly the same thing a couple of times. A rock hard brake pedal and then a click when I press start. It did it twice this mornig before successfully engaging the starter.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #645688 Tue Dec 10 2024 7:00am
RallyeSport
I still get the hard pedal on the odd occasion myself.
I put it down to a possible vacuum leak somewhere, I'll investigate further as it gets worse.
All I updated was the IPC file which gave me the 2012 instruments upgrade 'look'.
I didn't upgrade the main engine ECU flash program.
I just press the pedal harder if it fails to trigger the starter.
Not entirely sure what the issue is, other than a possible leak.
Maybe others could shed some extra light on the subject.
Dean
Post #645691 Tue Dec 10 2024 9:41am
TTR
Eh up all,
Well the cars being starting with no issues, brake pedal still feels hard though so I’m not confident there isn’t a problem Neutral
I’ve been flat out at work with no time to get it to a garage to code read, maybe get chance after Christmas
I’m sure there’s a issue and I know simply keeping my fingers crossed is not a plan Rolling with laughter
Rallyesport- that’s exactly my symptoms Thumbs Up
Post #645698 Tue Dec 10 2024 8:07pm
Jabba
Thanks for your replies guy's, much appreciated.
It's strange, it did it again, twice, yesterday and then the last two times the brake pedals been normal and its started normally too, bizarre !
I read on the ffrr forum that someone, with simialr experiences, changed the starter relay, as it was pitted, this seemed to have solved their issue. I've ordered a new relay, I'll change it and will monitor it.
I know that it will start, normally on the third attempt, but it shouldn't be like this.
Many thanks
Post #645702 Wed Dec 11 2024 6:01am
JonnyCJ
Check your battery connections. The 10mm bolt that held one of the secondary cables onto the main pos clamp needed nipping up.
Post #645703 Wed Dec 11 2024 6:48am
