Home > Technical > HELP "only normal height available"
Echobeach99
Hi all, apologies as I'm new here, female and not great with 'car language' lol!
I've a 66 plate RRS and the above issue has come up on my car. I've read through this forum and can see others have issues.
However, my issue is that the suspension rises and falls in all settings OK.
The compressor is working well and I've checked the pipes leading to it too (no leaks, splits etc) .. I'm stuck what to check next....
Please help , thank you in advance Smile
Post #644950 Tue Oct 29 2024 9:01am
Karlp606
You need a new one of these on the compressor ;
https://www.ebay.co.uk/itm/235466678923?ch...PqEALw_wcB
Easy to swap yourself just unscrews from the compressor, compressor is under the boot lid, check youtube as theres a few videos , easy DIY job. Thumbs Up
Post #644952 Tue Oct 29 2024 10:00am
Echobeach99
Hi thank you.
What does the part you suggested do please?
Post #644953 Tue Oct 29 2024 10:26am
Karlp606
It allows the air out of the exhaust , so if the air cant be released at the correct pressure from the compressor it throws the error.
Post #644954 Tue Oct 29 2024 10:41am
Echobeach99
Ah thank you.
Much appreciated 👏
I'll give it a go Smile
Post #644955 Tue Oct 29 2024 11:40am
Echobeach99
I replaced the part easily (old one was corroded on inspection) but the error is still there.
I've taken videos of the suspension rising up and down and it appears on off road setting the front is slower to rise.
Code C1A20-64
Any suggestions please?
Post #645083 Sun Nov 03 2024 10:02pm
Karlp606
Hmmmmm, Im not too sure personally unless the full compressor is getting 'lazy' so its kicking out a code now and again. Basically on its way out.
Can anyone else help shed any light on this..
Post #645085 Mon Nov 04 2024 8:50am
It raises the rear first, and then the front. So that it what you are seeing on video
C1A20-64, pressure increase too slow when filling reservoir
So a compressor service seams like a sensible way forward. Make sure you know what brand is fitted before ordering parts from ebay. And look up videos on youtube on how to service.
Brand could be AMK
Post #645087 Mon Nov 04 2024 11:12am
Echobeach99
Hi thank you.
Yes the one I have is an AMK. I've been told to stay away from the Hitachi ones
Post #645088 Mon Nov 04 2024 11:33am
Echobeach99
Brand could be AMK
Hi sorry I've looked and cany find the service videos 😞
Post #645091 Mon Nov 04 2024 2:22pm
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
As Andy says, it raises thr rear first so that the headlights (if on) won't dazzle the opposition.
Post #645092 Mon Nov 04 2024 2:27pm
Echobeach99
Hi Yes. Mind does that still although v slow coming up at the front.
Still throwing the same error.
Post #645093 Mon Nov 04 2024 2:31pm
If you don't feel confident, then maybe just buy a new one, or at least find out who has in stock, if you need one in a hurry
You want a piston and/or piston seal as well if you can get one
Post #645097 Mon Nov 04 2024 3:25pm
Echobeach99
That's great thank you.
I'll give it a go 😀
Post #645098 Mon Nov 04 2024 3:47pm
