![]() | Home > Technical > HELP "only normal height available" |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 254 ![]() |
You need a new one of these on the compressor ;
Echobeach99 Member Since: 15 Oct 2024 Location: Wiltshire Posts: 8 ![]() ![]() |
Hi thank you.
It allows the air out of the exhaust , so if the air cant be released at the correct pressure from the compressor it throws the error. |
Ah thank you.
I replaced the part easily (old one was corroded on inspection) but the error is still there.
Hmmmmm, Im not too sure personally unless the full compressor is getting 'lazy' so its kicking out a code now and again. Basically on its way out.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
It raises the rear first, and then the front. So that it what you are seeing on video
Hi thank you.
Hi sorry I've looked and cany find the service videos 😞 |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 ![]() ![]() ![]() |
As Andy says, it raises thr rear first so that the headlights (if on) won't dazzle the opposition. |
Hi Yes. Mind does that still although v slow coming up at the front.
If you don't feel confident, then maybe just buy a new one, or at least find out who has in stock, if you need one in a hurry
That's great thank you.
