Home > General > P0234-77 Turbo Overboost - SDV6 L494 |
SAK335 Member Since: 02 Apr 2022 Location: Henley-on-Thames Posts: 22 |
No coding is necessary. It's a pretty straightforward replacement. |
Tue May 09 2023 3:56pm |
Fozza RR Member Since: 06 May 2023 Location: West Midlands Posts: 3 |
Thanks for the reply, I have had it off to clean and it was really gunked up
Tue May 09 2023 6:15pm |
The dealers are clueless. The throttle causes the error code and the error code suspends DPF regeneration. The DPF will clog again. Go to YouTube and look up a guy called OReillys Mobile Mechanics. He's put out some good videos on this issue on JLR vehicles and shows how to clean the DPF without removing it. |
Tue May 09 2023 7:47pm |
PhilMid Member Since: 14 Aug 2015 Location: Hull, East Yorkshire Posts: 61 |
They did a software update when I had my throttle body replaced. Don’t completely know why it had to be done, but it’s been fine since the throttle body change.
Tue May 09 2023 10:12pm |
Sitchey Member Since: 11 Jul 2021 Location: Armagh Posts: 9 |
Hi. Did you ever get yours sorted fully? I've 2015 RRS and going around in circles. P24A4-97 Diesel particle filter restriction- soot accumulation too high - bank 1 State: Intermittent P0234-77 Turbo/supercharger overboost condition State: Intermittent I have had my DPF flushed and a brand new throttle body installed. Keep getting the same issues over and over. My turbo pressure is fine and no whines and evident smoke. But something still isn't right. |
Mon Sep 16 2024 10:24pm |
SAILORSAM Member Since: 11 Nov 2023 Location: HAYLING Posts: 6 |
Getting the same but the turbo over pressure only seems to be triggered by the car trying to do a regen. In normal use no fault comes up but when I go to force a region via tool, it triggers the fault and won't regain. Have cleaned the DPF and new LR Throttle body |
Mon Oct 14 2024 8:53am |
Getting the same but the turbo over pressure only seems to be triggered by the car trying to do a regen. In normal use no fault comes up but when I go to force a regen via tool, it triggers the fault and won't regen. Have cleaned the DPF and new LR Throttle body
Mon Oct 14 2024 9:00am |
2 things to consider that might help
Mon Oct 14 2024 11:34am |
Any idea how to do the software reset? I have a Gapp-IID tool but doesn't seem to have anything to do it |
Mon Oct 14 2024 11:49am |
Sorry my mechanic did it in a few secs. Tool I had didn't have the option |
Mon Oct 14 2024 11:25pm |
So i changed the Throttle body and the Oil breather and took it for a run. When i use the gap iid to try and force regen the Dpf it immediately fails with code P0234-77 happening. Cleared the fault and then drove for a while to find the car then did its own regen and didnt trigger the code! |
Sun Oct 20 2024 5:46pm |
Hope that's it sorted for you. Mine has been fine since those 2 steps.
Sun Oct 20 2024 6:43pm |
