Home > General > P0234-77 Turbo Overboost - SDV6 L494 |
SAK335 Member Since: 02 Apr 2022 Location: Henley-on-Thames Posts: 22 |
No coding is necessary. It's a pretty straightforward replacement. |
Tue May 09 2023 3:56pm |
Fozza RR Member Since: 06 May 2023 Location: West Midlands Posts: 3 |
Thanks for the reply, I have had it off to clean and it was really gunked up
Tue May 09 2023 6:15pm |
The dealers are clueless. The throttle causes the error code and the error code suspends DPF regeneration. The DPF will clog again. Go to YouTube and look up a guy called OReillys Mobile Mechanics. He's put out some good videos on this issue on JLR vehicles and shows how to clean the DPF without removing it. |
Tue May 09 2023 7:47pm |
PhilMid Member Since: 14 Aug 2015 Location: Hull, East Yorkshire Posts: 61 |
They did a software update when I had my throttle body replaced. Don’t completely know why it had to be done, but it’s been fine since the throttle body change.
Tue May 09 2023 10:12pm |
Sitchey Member Since: 11 Jul 2021 Location: Armagh Posts: 5 |
Hi. Did you ever get yours sorted fully? I've 2015 RRS and going around in circles. P24A4-97 Diesel particle filter restriction- soot accumulation too high - bank 1 State: Intermittent P0234-77 Turbo/supercharger overboost condition State: Intermittent I have had my DPF flushed and a brand new throttle body installed. Keep getting the same issues over and over. My turbo pressure is fine and no whines and evident smoke. But something still isn't right. |
Mon Sep 16 2024 10:24pm |
