Home > General > P0234-77 Turbo Overboost - SDV6 L494
Fozza RR
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Throttle body fitting
Hi, I have the same error message and want to change the throttle body. Can you just fit a new one or does it need programming. Thanks for your help.
Post #632914 Sat May 06 2023 9:07pm
SAK335
No coding is necessary. It's a pretty straightforward replacement.
Post #632968 Tue May 09 2023 3:56pm
Fozza RR
Thanks for the reply, I have had it off to clean and it was really gunked up
with black oil and soot deposits. I have now had the red dpf filter fault come up
and it is at present having the dpf removed and deep cleaned under warranty.
I have read on here that it’s the throttle body that causes this but I can’t get
the dealer to change it because they think just cleaning the dpf will fix it.
I think I will just do it myself £500 is a small price to pay for piece of mind.
Post #632972 Tue May 09 2023 6:15pm
SAK335
The dealers are clueless. The throttle causes the error code and the error code suspends DPF regeneration. The DPF will clog again. Go to YouTube and look up a guy called OReillys Mobile Mechanics. He's put out some good videos on this issue on JLR vehicles and shows how to clean the DPF without removing it.
Post #632975 Tue May 09 2023 7:47pm
PhilMid
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
They did a software update when I had my throttle body replaced. Don’t completely know why it had to be done, but it’s been fine since the throttle body change.
I was also getting DPF issues and had it cleaned after numerous warning lights appeared, and kept appearing after the DPF clean, and didn’t stop until throttle body changed.
It’s been good for 18+ months now, whereas it was about a day until the throttle body was changed
Phil
Post #632978 Tue May 09 2023 10:12pm
Sitchey
Hi. Did you ever get yours sorted fully?
I've 2015 RRS and going around in circles.
P24A4-97
Diesel particle filter restriction- soot accumulation too high - bank 1
State: Intermittent
P0234-77
Turbo/supercharger overboost condition
State: Intermittent
I have had my DPF flushed and a brand new throttle body installed. Keep getting the same issues over and over.
My turbo pressure is fine and no whines and evident smoke. But something still isn't right.
Post #644272 Mon Sep 16 2024 10:24pm
SAILORSAM
Getting the same but the turbo over pressure only seems to be triggered by the car trying to do a regen. In normal use no fault comes up but when I go to force a region via tool, it triggers the fault and won't regain. Have cleaned the DPF and new LR Throttle body
Post #644713 Mon Oct 14 2024 8:53am
SAILORSAM
Getting the same but the turbo over pressure only seems to be triggered by the car trying to do a regen. In normal use no fault comes up but when I go to force a regen via tool, it triggers the fault and won't regen. Have cleaned the DPF and new LR Throttle body
Any ideas where next
Post #644714 Mon Oct 14 2024 9:00am
Sitchey
2 things to consider that might help
1. When you change the throttle body make sure it the new one is programed in. Any easy step but if its not setup as new the car still things things it's an issue.
2. I read on forums the oil Breather can also cause these issues. I changed mine and so far this and the above have stopped the issue coming back (1 month on).
My issue I now have is the oil monitor level issue. It has come on twice in 2 months but dissappear on its own. I'm looking into this and hope it might be a battery or software issue and won't need to remove the sump to change a stupid sensor.
Post #644720 Mon Oct 14 2024 11:34am
SAILORSAM
Any idea how to do the software reset? I have a Gapp-IID tool but doesn't seem to have anything to do it
Post #644721 Mon Oct 14 2024 11:49am
Sitchey
Sorry my mechanic did it in a few secs. Tool I had didn't have the option
Post #644741 Mon Oct 14 2024 11:25pm
SAILORSAM
So i changed the Throttle body and the Oil breather and took it for a run. When i use the gap iid to try and force regen the Dpf it immediately fails with code P0234-77 happening. Cleared the fault and then drove for a while to find the car then did its own regen and didnt trigger the code!
Post #644809 Sun Oct 20 2024 5:46pm
Sitchey
Hope that's it sorted for you. Mine has been fine since those 2 steps.
Only issue I have now is the oil monitor sensor that is coming infrequently.
Post #644813 Sun Oct 20 2024 6:43pm
