Home > General > Ace delete problem
Mine
Ace delete problem
Hi I’m new to this forum, my problem is I own a 2010 Range Rover sport tdv8 and the ace anti-roll bar valve block and pipe work is leaking more oil than the Exxon Valdez . I’ve purchased a new ace delete kit and taken it to my local Land Rover specialist in Cheshire. They have started to look at the car today and come back to me saying that the kit can be fitted but they can’t delete the fault from the ecu because my car is on a change over year and the ecu is locked ? I’m stuck now because if they fit the kit the red lights and warning sound will still be on ( because this is a red light it would not pass an MOT). Is there any body that has come across this problem before your advice would be very much appreciated. Also if the ecu can be unlocked does anyone know of a specialist in Cheshire that can update my ecu once the kit has been fitted.
Any advice would be greatly appreciated.
Thanks Bob.
Post #644529 Thu Oct 03 2024 4:17pm
RangeRoverSport24
United Kingdom 2009 Range Rover Sport TDV6 HSE Orkney Grey
I'm having the same issue. I'm unsure if it's the anti roll ace pump. If someone can help or explain how I even take it out, I'd be grateful.
Post #644755 Tue Oct 15 2024 5:10pm
erickwan
Malaysia
Re: Ace delete problem
Thanks Bob.
Just remove the relevant leds in the dash. Rolling with laughter
Post #644762 Wed Oct 16 2024 12:42am
RangeRoverSport24
My belt snapped, and the pullie roll thing is snapped or lose. I can't put new belt on till I replace it. But I can't get it out and don't don't where to find a cheap replacement
Post #644764 Wed Oct 16 2024 6:13am
