Home > General (L461) > L461 - issue - fuel filler cover not flush fitting.
Page 5 of 5 <12345
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Wish you hadn’t mentioned it as thought mine was okay until I looked closely. Now it seems to have reverted to how it was originally with about 2mm protruding at top and generally not fitting correctly.
In for 1st full service tomorrow so will raise it at dealer.
Post #644623 Tue Oct 08 2024 10:26pm
JDPRRSUK
Had full first year service today and all well. They decided that fuel filler cap has warped and need replacement - one on order.
Apparently the early (MY23/MY24) had a fuel cap made that was prone to warping in different temps hence changes over time. They now have a different plastic and mold to make new ones that don’t deform. Let’s see when mine arrives!
Post #644634 Wed Oct 09 2024 9:58pm
bimjim
Thanks for the update. Hopefully the new one, when it arrives, does the trick. 2023 P440e Dynamic SE
Post #644636 Wed Oct 09 2024 10:08pm
JDPRRSUK
Got call today from dealer to say new fuel filler cap had arrived and all painted ready to fit. Apparently needs adjustment as well from inside wheel liner so 2 hour job next week. Will update how it goes…
Post #644852 Tue Oct 22 2024 9:22pm
bimjim
Let us know how you get on. I'm planning to get mine looked at next month. 2023 P440e Dynamic SE
Post #644907 Fri Oct 25 2024 5:09pm
JDPRRSUK
Will do - it is booked in for next Thursday
Post #644910 Fri Oct 25 2024 10:39pm
JDPRRSUK
Got mine replaced today - painted at factory and sent to dealer.. before and after pics
Post #645005 Thu Oct 31 2024 6:46pm
JDPRRSUK
Post #645006 Thu Oct 31 2024 6:47pm
scrumps
That looks better!
Is the new one made from the new plastic?
Is there a revised part number?
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #645008 Thu Oct 31 2024 6:57pm
JDPRRSUK
It fits as it should now and inside is flush with the plastic hinge.
Not sure about new part number but it definitely feels stiffer and it came pre painted from factory. Was told they have changed the material to stop warping - which did seem to happen to mine in different temps.
Post #645015 Fri Nov 01 2024 6:39am
Page 5 of 5 <12345
