Home > Maintenance & Modifications > Restricted performance
Grimble
Never seen this in over 4 years of ownership. Just came on about 5 miles after leaving home. Stopped at a mates 2 miles later. Started up again after 30 mins and no light came on. Ran around town a bit all ok. Came on again after a few miles on the way home, again after a short stop it was clear.
Battery seems fine and everything else is working without any warning lights on. Mostly use the car for longish motorway journeys and it's never missed a beat.
Any clues what to look for before I book it in?
I don't have a code reader. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #644506 Wed Oct 02 2024 5:55pm
NoExpert
My first guess is IAP/MAF correlation. Somewhere between the MAF and inlet manifolds is a leak. Loose hose clip, split pipe, split manifold, etc.
Next guess would be a secondary turbo solenoid sticking. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #644508 Wed Oct 02 2024 11:07pm
Sounds like a split inlet manifold. Does it do it when you accelerate and get the revs up? Turning off and on again resets it until the next time the split opens. 2012 SDV6 - it's missing a couple of cylinders
Post #644519 Thu Oct 03 2024 9:58am
Grimble
Thanks for the replies. Other than code reading, is there a physical check I can do? Are the inlet manifolds easy to inspect without removal. I'm handy enough mechanically, but not on engines this complex. Can a leak be heard? RRS HSE Dynamic SDV6 2014
Post #644521 Thu Oct 03 2024 11:24am
When my manifold split, the indie that I use said they do a quick check by doing a torque converter stall check - stand on the brakes and add throttle 'til it won't rev any more (about 2.5k revs). Apparently, the inlet manifold split can be heard to whistle quite noticeably. Obviously, you need a trusted helper to do this more easily. 2012 SDV6 - it's missing a couple of cylinders
Post #644522 Thu Oct 03 2024 12:28pm
Grimble
Restricted performance (update)
Smoke test done.
Both mainfolds split, the drivers side badly, the passenger side not so much.
Funnily enough I noticed a significant increase in fuel consumption on my last long trip, which I make regularly and the indy confirmed that a split manifold would have this effect although it was unusual to have both go at the same time.
So next question, do I go for an original LR part or is there an alternative OEM that could be recommended?
Dont fancy paying a lot for a branded cardboard box. RRS HSE Dynamic SDV6 2014
Post #644591 Mon Oct 07 2024 1:17pm
Found this on the sister site, not sure if it's useful. https://www.disco3.co.uk/forum/30-sdtdv6-i...05583.html 2012 SDV6 - it's missing a couple of cylinders
Post #644594 Mon Oct 07 2024 3:26pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Re: Restricted performance (update)
Grimble wrote:
Smoke test done.
In this scenario, I'd be going genuine, it's a big labour job, you don't want to be tackling again, buy cheap, buy twice definitely applies in this case. Early MY vehicles were susceptible to failures as the cover was the same design for the single turbo engines, but with the SDV6 the boost pressure is higher hence the failures, hence LR re-designed them mid 2015.
Post #644601 Mon Oct 07 2024 8:30pm
Grimble
Job done. One was cracked and the other was split on the seam. I think these were the original parts as the fomoco logo was visible. Hopefully that's it for a while.
Rather poor engineering design I think to have such a critical part fail in this way. RRS HSE Dynamic SDV6 2014
Post #644830 Tue Oct 22 2024 8:35am
2 RRS
The covers were carried over from the TDV6 single turbo engine that ran less boost, where they were adequate, LR realised mid 2015 they were too weak for the SDV6 and hence redesigned them. You should be OK from now on.
Post #644831 Tue Oct 22 2024 8:45am
Grimble
Quick run up the M6 yesterday to West Lancs. 170 mile round trip. May be imagining it but the engine has never felt better. RRS HSE Dynamic SDV6 2014
Post #644881 Thu Oct 24 2024 8:11am
NoExpert
That happens when you plug the air leaks. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #644891 Thu Oct 24 2024 3:17pm
erickwan
Malaysia
My assumption is with multiple part numbers, there must be a revision with each successive number, and the previous ones are unacceptable by Ford / Citroen / Land Rover.
Post #644902 Fri Oct 25 2024 2:16am
ShouldHaveStuckWithAudi
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Hi all, hopefully not too old to jump on this thread.... I've effectively had the same intermittent thing and so have checked everywhere for obvious leaks or cracks and can't find any. I've taken most of the (accessible) intake system apart and cleaned it and then did a 'mouth test' where I blew (until I nearly blacked out) into the hose connected to the intercooler outlet to pressurise the throttle and inlet manifolds. Seemed to hold pressure really well.
When I blew the other way (blocking the air box) I got a slight loss from a cracked vacuum line that runs between the two inlet manifold - so I fixed that (using some 5mm high temp silicone hosing btw) and then it held well.
DTC's are P006A and P1247. SDD suggests if only these two then it's a high pressure leak on bank 2 (passenger side correct?) in bi-turbo mode.
So questions:
    * Any chance the broken vacuum line could be the source of the restricted performance?
    * What is the max boost these 306dt engines run at? Something like 25psi?
    * Given humans can only produce about 0.3 bar pressure, is my test at all valid or do I really need to do a smoke test?
    * Has anyone made a DIY smoke machine and what pressure do you need to run the test at?
Any thoughts or suggestions would be welcome.... Am trying to avoid having to replace the intake manifolds...
Post #645936 Fri Dec 27 2024 8:16pm
Disco_Mikey
99 times out of 100, its a manifold...
Look for the oil vapour on the top of the cam cover Thumbs Up
Post #645939 Fri Dec 27 2024 8:57pm
