![]() | Home > Maintenance & Modifications > Restricted performance |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
When mine split it started with only happening under heavy acceleration. Then progressed to light acceleration.
ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 32 ![]() ![]() ![]() |
Thanks all. Am still struggling to see any particular oil leak (mist or otherwise) as there is generally oil everywhere (only diesels I've ever owned is this one and the 09 version I upgraded from so don't know how much oil is normal for these dirty engines).
Oil everywhere? Not exactly normal without things leaking. Where is the oil? If it’s at the front of the engine under the throttle body your throttle body could be split at a seam and blowing oil out there. Mine did this. Took a while to find since everything looked okay, but there was always oil at the front of he engine even after cleaning it.
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
Turbo hose leak and egr o ring were culprits on mine.
Sorry for the delay in replying - i don't get messages anymore when a new response is posted so missed these.
