![]() | Home > General (L461) > MY23/24 |
bimjim Member Since: 17 May 2010 Location: Hertfordshire Posts: 88 ![]() ![]() |
If you're going PHEV, the newer MY24 models have a different electric motor which will give more power and more range (supposedly). 2023 P440e Dynamic SE |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 546 ![]() ![]() |
Chips Member Since: 08 Nov 2017 Location: Shropshire Posts: 123 ![]() ![]() |
Just picked up a 73 plate MY24 and was very nervous about losing the dials , in fact I almost pulled out of the deal once I realised, however I need not of worried , the temprature works very well on the screen , On a loan car I was pressing the temprature display to get the adjustment arrows up, but you don't need to do this, you just touch the screen and slide your finger up or down all in a single touch so just as quick and easy as dials.
Alltalk Member Since: 15 Feb 2017 Location: Cambridge Posts: 22 ![]() ![]() |
Thanks all, that’s encouraging, feared the screen only option would be a nightmare. Just need to find one with a towbar that isn’t black (love black it doesn’t love me). Will be diesel hse dynamic so well spec’d doesn’t need any options as far as I can see. |
Chips,
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 ![]() |
Another critical difference between 23MY/24MY is that 23MY was only available with the shocking base sound system. 24MY saw the return of 3D and Signature. |
Tizzy Member Since: 30 Dec 2023 Location: Leicestershire Posts: 33 ![]() ![]() |
Have to admit I’ve not noticed the “Country Road” lane assistance on my April 24 car, though living in the sticks I doubt it will work too well - I generally turn it off unless I’m on a major road where it can be useful. Nearly all the functions onscreen like volume and temperature actually operate with a swipe up or down, so are very simple to use in practice. |
The audio sounds like a biggie, can you tell visually or is it “has only screen and no dials means better audio” |
Not sure - mine says Meridian Surround on it if that helps? D/door tweeter box still rattles though🤬 |
Correct. You need the front door tweeters and the rear door labels to say ‘Meridian 3D Surround’ as a minimum. The base sound system is diabolical for the price point. |
It's an addition to adaptive cruise where by it automatically slows down for corners etc. It also alters speed for changing speed limits but not sure if that bit was on earlier MY cars MY24 Dynamic SE,MY21 HSE Silver, MY20 SQ7, MY 18 RRS HSE Dynamic , MY 16 RRS Autobiography now gone & MY 2005 Discovery 3 HSE that I will be buried in ! |
