Home > Technical > Broken crank |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1158 |
ouch, sorry to hear that mate
Fri Apr 05 2024 10:36am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4891 |
It it’s a 3.0 oval autos. |
Fri Apr 05 2024 12:24pm |
pjdow Member Since: 01 Dec 2021 Location: Sheffield Posts: 5 |
2015/16
Fri Apr 05 2024 9:13pm |
if your services were at a Land Rover dealer, you should approach them for a claim --
Fri Apr 05 2024 9:15pm |
Sadly the last 3 years are local specialists, but logged on the landrover service portal. |
Fri Apr 05 2024 9:19pm |
I think you still have a chance here: take it to the last LR dealer you used and request a goodwill claim. --
Fri Apr 05 2024 9:20pm |
Crs Member Since: 04 Sep 2022 Location: Hampshire Posts: 82 |
Sorry to hear this , you must be devastated, how landrover ever got away with this catastrophic failure I will never understand, as said see if you can get something out of them but I wouldn’t hold your breath on it. Land Rover should have been taken to court over this.
Mon Apr 08 2024 6:48am |
To put this one to bed
Fri Jun 28 2024 1:31pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 128 |
Does this ever happen to Ford, Jaguar and Citroen? |
Fri Jun 28 2024 2:19pm |
Yes, but the volumes sold, particularly with Citreon and Peugeot make is less visible. |
Fri Jun 28 2024 3:19pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 325 |
Following on a bit - from what I’ve gleaned from speaking to those in the know, a snapped crank can result in a warped engine case. This then makes the case junk, but apparently it’s the rods that are the problem, as you can’t get them, so to rebuild an engine, you need to cannibalise good rods from another broken engine. |
Sat Jun 29 2024 6:31pm |
feel very sorry for this chap, first time I hear of this in an F-Pace: https://www.4x4community.co.za/forum/showt...ost5259042
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Sat Jul 13 2024 12:43pm |
