Home > Technical > Broken crank
pjdow
Broken crank
Hi
My crank has broken, in Europe on holiday
Annoying to say the least.
Any recommended repairers is the question
Grateful for any suggestions
Regards
Post #640941 Fri Apr 05 2024 7:57am
ouch, sorry to hear that mate Sad
What is the year & mileage?
If you have FSH with Land Rover, you could approach them for a goodwill claim? --
Post #640947 Fri Apr 05 2024 9:36am
It it’s a 3.0 oval autos.
Post #640960 Fri Apr 05 2024 11:24am
pjdow
55000
13 services
Post #640983 Fri Apr 05 2024 8:13pm
if your services were at a Land Rover dealer, you should approach them for a claim --
Post #640984 Fri Apr 05 2024 8:15pm
pjdow
Sadly the last 3 years are local specialists, but logged on the landrover service portal.
Post #640985 Fri Apr 05 2024 8:19pm
I think you still have a chance here: take it to the last LR dealer you used and request a goodwill claim. --
Post #640986 Fri Apr 05 2024 8:20pm
Crs
England 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Sorry to hear this , you must be devastated, how landrover ever got away with this catastrophic failure I will never understand, as said see if you can get something out of them but I wouldn’t hold your breath on it. Land Rover should have been taken to court over this.
Good luck
Post #641032 Mon Apr 08 2024 5:48am
pjdow
To put this one to bed
I spoke to 4 different garages about the problem and an engine builder.
I won't mention the many experts on Facebook talking complete rubbish
The engine builder was interesting, as he had knowledge of the Lion V6 problems but does not work on them. He gave me 30 minutes of his time offering suggestions and pointers to look out for.
The main point being "do not fit Chinese or Turkish pattern crankshafts" the are very difficult to balance properly and often fail.
Of the 4 I spoke to only one gave me the same independent narrative about what can and cannot be done with a broken engine.
As it happens the crank had not broken but I had spun a bearing.
A new block, secondhand block, was sourced and the original crank reused as it was not damaged.
I have not had the car back a week and covered 700 miles so far. All good.
Fingers crossed for the future!
The company I used : - Oval Auto's, as recommended on here by Andy K.
Post #642904 Fri Jun 28 2024 12:31pm
erickwan
Malaysia
Good luck
Does this ever happen to Ford, Jaguar and Citroen?
Post #642906 Fri Jun 28 2024 1:19pm
pjdow
Yes, but the volumes sold, particularly with Citreon and Peugeot make is less visible.
Post #642911 Fri Jun 28 2024 2:19pm
JonnyCJ
Following on a bit - from what I’ve gleaned from speaking to those in the know, a snapped crank can result in a warped engine case. This then makes the case junk, but apparently it’s the rods that are the problem, as you can’t get them, so to rebuild an engine, you need to cannibalise good rods from another broken engine.
Post #642933 Sat Jun 29 2024 5:31pm
feel very sorry for this chap, first time I hear of this in an F-Pace: https://www.4x4community.co.za/forum/showt...ost5259042
Quote:
2017 F-Pace 3.0d AWD R-Sport
Serviced at JLR Stellenbosch in March 2024 at 82000km. Engine packed up at 84000km in May 2024 while driving 30km/h in a residential area. Initial quote was ZAR370 000 to replace engine. JLR stellenbosch offered to assist ~R70 000, putting cost of repair at R300 000
Assessment from JLR
The common fault we have encounter with these engines (3,0 TDV6) is that the crank shaft main bearings turns within the casing, when this happens
The oil supply to the bearings are then cut off causing bearing failure and then complete crankshaft failure. The crank shaft then breaks internally
Distorting the engine block causing irreparable damage to the engine assembly.
Post #643244 Sat Jul 13 2024 11:43am
