![]() | Home > My Range Rover Sport > Range rover l320 suspension issue |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4887 ![]() ![]() ![]() |
Maybe a short in wire to rear block ?
LegendZilla Member Since: 28 Apr 2024 Location: Abha Posts: 3 ![]() ![]() ![]() |
But if it was a short somewhere it should log a fault code right? Also I didn’t try to unplug the rear valve block, but if so would the compressor still kick in to fill the reservoir? Or the fault will stop it? I will give that a try |
It is possible the whole system will lock out.
Update:
