Home > My Range Rover Sport > Range rover l320 suspension issue |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
Maybe a short in wire to rear block ?
Sun Apr 28 2024 2:33pm |
LegendZilla Member Since: 28 Apr 2024 Location: Abha Posts: 3 |
But if it was a short somewhere it should log a fault code right? Also I didn’t try to unplug the rear valve block, but if so would the compressor still kick in to fill the reservoir? Or the fault will stop it? I will give that a try |
Sun Apr 28 2024 3:09pm |
It is possible the whole system will lock out.
Sun Apr 28 2024 3:57pm |
Update:
Sat May 11 2024 6:35am |
