Home > My Range Rover Sport > Range rover l320 suspension issue
LegendZilla
Saudi Arabia 2006 Range Rover Sport 4.4 V8 HSE Chawton White
I have a 2006 range rover sport and I’m pulling my hair right now :/
The issue with Air suspension is so weird
Compressor keeps running, filling and discharging again and again until it burnt.
I bought a new one and installed guess what? Same issue
I found the problem 🥲 whenever the compressor starts to fill the reservoir the right rear strut goes up, the computer sees it’s going up by itself then it opens the exhaust valve and so on…
I replaced both front and middle valve blocks with a new ones, replaced the rear valve block with a good known one, same issue… I have a diagnostic tool and I can see live data, the strut is being filled without a permission from air suspension module.
Please any help would be much appreciated
Post #641574 Sun Apr 28 2024 2:23pm
Maybe a short in wire to rear block ?
Get it to normal height and unplug rear block.
See what happens.
Post #641576 Sun Apr 28 2024 3:33pm
LegendZilla
But if it was a short somewhere it should log a fault code right? Also I didn’t try to unplug the rear valve block, but if so would the compressor still kick in to fill the reservoir? Or the fault will stop it? I will give that a try
Post #641577 Sun Apr 28 2024 4:09pm
It is possible the whole system will lock out.
You could run the compressor yourself and prove the right doesn’t lift. And TRY and prove it’s electrical
Post #641578 Sun Apr 28 2024 4:57pm
LegendZilla
Update:
Found the issue Mr. Green it turned out the used “known as good” rear suspension valve
It was leaking internally causing compressor air to fill the strut without permission from the module
Finally fixed with a new aftermarket valve
Thank you everyone 😁
Post #641859 Sat May 11 2024 7:35am
