Home > In Car Electronics > L320 2011 stereo/ dvd/ Bluetooth issue
Alan1981
United Kingdom 2011 Range Rover Sport SDV6 Autobiography Santorini Black
Hi guys I have an issue with my infotainment system, basically firstly when you unlock the car it takes longer to boot up( ie the land rover symbol takes longer to load up in the screen)
Then I'll be driving along and there will be like a small pop noise and it just shuts off, if I pull the fuse and put it back, it comes back to life the eventually does the same
So far I've changed the battery, checked the alternator done a ecu reset, pulled and checked every fuse and nothing has changed.
I am wondering if anyone has come across this or a similar issue, as am really not sure what to look at next
Post #641288 Fri Apr 19 2024 12:41pm
Usually the Bluetooth unit or amp.
You can buy a MOST orange bypass cable off eBay to remove the Bluetooth to see if that gets rid of the problem. To help diagnostics.
Post #641289 Fri Apr 19 2024 1:00pm
Alan1981
You could be right with blue tooth as every now an again it won't connect to my phone, is the Bluetooth module in the boot behind the drivers side panel?
Post #641290 Fri Apr 19 2024 1:15pm
I believe so
Post #641291 Fri Apr 19 2024 1:24pm
Alan1981
I got a friend breaking one, maybe if he is selling the modules cheap I might just buy them off him but the Bluetooth one is definitely a target due to connectivity issues in the past.
Post #641292 Fri Apr 19 2024 1:34pm
I think you may find the Bluetooth module is a integrated part of the IAM unit on a facelift vehicle, not a separate unit in the boot.
Post #641312 Fri Apr 19 2024 9:41pm
2011 should be older system. But it is a bit close to the 2012 changer over.
Post #641316 Sat Apr 20 2024 8:11am
Alan1981
Mines the denso unit,which I belive is the older one, think new ones are bosch
Post #641331 Sat Apr 20 2024 4:36pm
Alan1981
Do I need to code them in btw?
Post #642336 Sun Jun 02 2024 2:27pm
no
but you need to get the correct amp. (well there were 2 on early ones, different colours)
Post #642341 Sun Jun 02 2024 4:39pm
