![]() | Home > In Car Electronics > L320 2011 stereo/ dvd/ Bluetooth issue |
Alan1981 Member Since: 19 Nov 2023 Location: Lincolnshire Posts: 10 ![]() ![]() ![]() |
Hi guys I have an issue with my infotainment system, basically firstly when you unlock the car it takes longer to boot up( ie the land rover symbol takes longer to load up in the screen)
You could be right with blue tooth as every now an again it won't connect to my phone, is the Bluetooth module in the boot behind the drivers side panel? |
I believe so |
I got a friend breaking one, maybe if he is selling the modules cheap I might just buy them off him but the Bluetooth one is definitely a target due to connectivity issues in the past. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
I think you may find the Bluetooth module is a integrated part of the IAM unit on a facelift vehicle, not a separate unit in the boot.
2011 should be older system. But it is a bit close to the 2012 changer over. |
Mines the denso unit,which I belive is the older one, think new ones are bosch |
Do I need to code them in btw? |
no
