Home > General > SVR Carbon bonnet issues & repair - warranty claim night
Teaboy
Hi - I've got some weird mark on my carbon bonnet on my SVR. (pictures attached) - Land Rover are claiming it's not repairable under warranty but I also discovered a SSM from Land Rover that seems to describe the exact symptoms... SSM 75913.
Anyone else had this issue and did you get LR to fix under (extended) warranty or repaired elsewhere.
Post #639890 Thu Feb 22 2024 5:58pm
Jjvd21
United States
Your pictures didn't show up 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE
Post #639892 Thu Feb 22 2024 6:53pm
Farmer Chalk
https://www.rrsport.co.uk/gallery/albums/u...81%29.jpeg
Post #639893 Thu Feb 22 2024 6:55pm
Teaboy
Post #639896 Thu Feb 22 2024 7:43pm
Red Arrow
Water under the lacquer Big Cry
Post #639903 Thu Feb 22 2024 9:26pm
Teaboy
How does that happen? Think it should be fixed under warranty?
Post #639905 Thu Feb 22 2024 10:19pm
Pistnbroke
Looking at the location it looks like heat damage which has destroyed the lacquer Always listen to old people or when they die you will live on in ignorance.
Post #639915 Fri Feb 23 2024 7:45am
Teaboy
What in the engine do you think caused that heat issue?
Post #639916 Fri Feb 23 2024 8:02am
Pistnbroke
Sitting in traffic Always listen to old people or when they die you will live on in ignorance.
Post #639917 Fri Feb 23 2024 8:30am
Jjvd21
United States
It is the paint clear coat peeling off of the top of the carbon fiber gel coat due to UV damage. It’s caused by the clear coat not being thick enough to provide proper UV protection. It should be fully repairable. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE
Post #639922 Fri Feb 23 2024 12:12pm
Svrdan
Did you resolve this with Landrover? I’ve got similar laquer peel on exposed carbon bonnet, car is going to main dealer on Monday for security update and will ask them about warranty claim (car is 2018 though so out of usual period, only chance is under anti corrosion warranty).
Post #640727 Tue Mar 26 2024 8:44pm
Martin0711
United Kingdom 2013 Range Rover Sport Supercharged Java Black
I’m now having the same issue and in exactly the same area.
Albeit it’s only a very small patch.
How did everyone get on in regards to dealing with landrover and warranty?? 2021 - Urban SVR
Post #645878 Fri Dec 20 2024 5:17pm
Svrdan
Was declined as warranty claim by dealer and then Landrover, currently with the Motor Ombudsman to decide - claim reviewed and initial case review / opened but told there is a big backlog and nothing heard since July! Could you post pics of your bonnet and year of your vehicle? Any further cases could be useful.
Post #645880 Fri Dec 20 2024 6:08pm
