Home > General > SVR Carbon bonnet issues & repair - warranty claim night |
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 242 |
Your pictures didn't show up 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
Thu Feb 22 2024 6:53pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 |
Thu Feb 22 2024 6:55pm |
Teaboy Member Since: 21 Oct 2018 Location: MK Posts: 13 |
Thu Feb 22 2024 7:43pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 |
Water under the lacquer |
Thu Feb 22 2024 9:26pm |
How does that happen? Think it should be fixed under warranty? |
Thu Feb 22 2024 10:19pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 419 |
Looking at the location it looks like heat damage which has destroyed the lacquer Always listen to old people or when they die you will live on in ignorance.
Fri Feb 23 2024 7:45am |
What in the engine do you think caused that heat issue? |
Fri Feb 23 2024 8:02am |
Sitting in traffic Always listen to old people or when they die you will live on in ignorance.
Fri Feb 23 2024 8:30am |
It is the paint clear coat peeling off of the top of the carbon fiber gel coat due to UV damage. It’s caused by the clear coat not being thick enough to provide proper UV protection. It should be fully repairable. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
Fri Feb 23 2024 12:12pm |
Svrdan Member Since: 26 Mar 2024 Location: Uk Posts: 4 |
Did you resolve this with Landrover? I’ve got similar laquer peel on exposed carbon bonnet, car is going to main dealer on Monday for security update and will ask them about warranty claim (car is 2018 though so out of usual period, only chance is under anti corrosion warranty). |
Tue Mar 26 2024 8:44pm |
Martin0711 Member Since: 25 Jan 2014 Location: Buckie Posts: 45 |
Fri Dec 20 2024 5:17pm |
Was declined as warranty claim by dealer and then Landrover, currently with the Motor Ombudsman to decide - claim reviewed and initial case review / opened but told there is a big backlog and nothing heard since July! Could you post pics of your bonnet and year of your vehicle? Any further cases could be useful. |
Fri Dec 20 2024 6:08pm |
svrjohn Member Since: 23 Jan 2025 Location: South Yorkshire Posts: 1 |
I have exactly the same issue on my 2019 35K miles dealer agrees that the issue is the laquer application is too thin and the UV light has caused the issue, Land rover have declided and said its ware and tear. |
Thu Jan 23 2025 9:54pm |
I've still heard nothing from the motor ombudsman a month on.
Fri Jan 24 2025 4:54pm |
