Home > General > RRS 2005 supercharged ..transmission error when drive engage |
Markieboy123 Member Since: 30 Apr 2019 Location: Hornchurch Essex Posts: 59 |
Forgot to add these additional errors come up on scan when you switch on lights and engage gear.
Mon Feb 12 2024 1:30pm |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 |
from the codes you may have more than issue... however, below are what i've seen....
Mon Feb 12 2024 2:52pm |
Thanks…
Mon Feb 12 2024 3:53pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
It would be worth going around the car ensuring the various earthing points are tight/connected/not corroded. Bad earths can cause a number of error issues.
Mon Feb 12 2024 4:18pm |
Thanks 👍
Mon Feb 12 2024 4:45pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1841 |
No point measuring the voltage at idle, measure the battery after its been standing at least overnight.
Mon Feb 12 2024 6:31pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4967 |
In the wiring loom are splices. This is where 3 or more wires join (crimped) together and get blue tape wrapped around them.
Mon Feb 12 2024 6:43pm |
Thanks will check that |
Mon Feb 12 2024 7:00pm |
Thanks Andy…. Yes you are right the green wire splice joint was not making contact and my key fob did not work, joined them and soldered now back have a working key fob. Looking to re-splice and solder all the blue tape joints…thanks for the pointer about the red wire, will look for that next…with the passenger seat removed I can access the whole loom in the sil. Will update if the red wire splice sorts the transmission error. |
Mon Feb 12 2024 7:06pm |
Respliced and soldered the red wires found in the passenger sill loom unfortunately still have the same error.
Tue Feb 13 2024 7:07pm |
Hi All,
Sat Feb 17 2024 5:41pm |
Search for the fault code on here or disco3
Sat Feb 17 2024 6:46pm |
Thanks Andy
Sat Feb 17 2024 7:26pm |
Reading up on a few forums …i believe it’s a voltage supply issue to the gear shifter if the headlight trick works, so will be looking at the fuses on the BCM fusebox.
Sun Feb 18 2024 8:05am |
