![]() | Home > General > RRS 4.2 S/C front driver side is leaning lower |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Would be easier to judge if we knew the how much does he charge for parts and which chunk of the 976 quid is labour. Regards etc.,
wiztaz Member Since: 28 Dec 2021 Location: Essex Posts: 41 ![]() ![]() |
Valve block suspension front - £223.13
Valve block suspension front - £223.13 2hr labour - £170 (£85PH) +VAT = £471 Shock absorber front -£230 + 20% VAT bolt - £11.44 nut - £3.79 2hr Labour £170 (£85PH) +VAT = £498.28 |
Is he proposing changing just the airbag or the whole strut? If it's the strut, it really ought to be changed as an axle pair - changing a single damper isn't a great idea, especially if the existing units are pretty old and tired.
They said the airbag can be changed individually and the valve. There was no mention of strut.
The £85PH labour seems pretty widely accepted, too. Regards etc.,
Yeah, the airbag can be done separately. Parts prices appear ok in that basis. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 428 ![]() ![]() |
Used valve blocks on eBay are £15 or so. You can change the seals yourself with a £20 kit.
PM sent back to you. I’ve done the front valve block at home and it’s not a 2 hour job. It’s more fiddly on a 4.2 due to the radiator, but I think my record was about 35 minutes. This link explains it (duckoby74’s post, not the first few).
JonnyCJ…thank you so much for all your help mate 🙌🏼 |
If its any help, I've just had 4 shocks (complete units and a new compressor fitted).
Christ |
It’s to calibrate the ride height after changing over components. If you’re not using the car this afternoon or evening, open the bonnet, take off the plastic battery cover and you’ll see the fuse box cover. Pop that off and remove fuse 3. It’s a 5A fuse, top left of the line of fuses, second one down I think from memory.
Picked up my 4.2 SC this afternoon after having the ride height calibrated and the adaptation software reset following me changing the ride height sensor and PCV valve.
