Home > General > FBH - Diesel dripping from exhaust connection
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi Folks.
I've been trying to resolve an intermittent fbh issue, whereby it sometimes fires and other times doesn't.
ACM-Audio System
U0166-00 - Lost communication with auxiliary heater control module (6Cool
AHCM-Auxilary Heater
B1D31-94 - Flame detected prior to normal operation - Component failure - unexpected operation (2C)
Whilst trying a few things, I've noticed that diesel is dripping out of the exhaust on the fbh where the exhaust port joins the concertina exhaust pipe and down onto the inner wing.
Has anyone else experienced this, and is there a way to resolve it. I'm assuming it's when the heater is priming as there's is no leak whilst it's running, when it rins that it.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #638976 Sat Jan 20 2024 4:14pm
It's dripping fuel because it has failed to start and you have unburnt fuel which has failed to ignite.
Post #638979 Sat Jan 20 2024 9:12pm
Jabba
Hi Col,
Many thanks, that would explain things.
Many thanks
Post #638980 Sat Jan 20 2024 9:13pm
gogsy1956
Had the exact same issue,, but mine would smoke like mad as the heater was still igniting a lot of the time. I found the ceramic insulator that houses the glow plug at the top of burner core was cracked,, and actually fell to pieces when I stripped it down. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #639011 Sun Jan 21 2024 9:55pm
Jabba
I removed my fbh on Friday, stripped and cleaned it. Luckily the ceramic was intacted still.
It dripped when trying to fire it up after refit, but it did the same before removing it.
Many thanks
Post #639012 Mon Jan 22 2024 1:51am
Re: FBH - Diesel dripping from exhaust connection
Jabba wrote:
Hi Folks.
Many thanks
Craig
That code to me indicates there may be a fault with the flame detector/sensor part of the glow plug, but that is only guess, I don't know for certain.
Post #639013 Mon Jan 22 2024 2:45am
Jabba
Hi Col,
Well, since the strip down and clean up at the weekend, touch wood, so far the fbh has been working correctly and with little or no smoke at present for the past couple of days, which is more than it did before.
Now, to find out what that bloody metallic scraping noise is when I pull away, sounds like something rubbing on either a brake shield, or perhaps, even one of the metal covers underneath, maybe the rear prop centre bearing is loose !
Many thanks
Post #639043 Tue Jan 23 2024 6:02am
Check you haven't just got a stone lodged between backplate and disc etc. before you get to excited about things.
Post #639044 Tue Jan 23 2024 6:13am
Jabba
Yes will do.
It's strange, sometimes it happens and then other times it doesn't.
I had a stone stuck between a caliper and a disc on another car, years ago, that really squelled !
Many thanks
Post #639045 Tue Jan 23 2024 6:21am
