![]() | Home > Technical > Fuel burning heater not starting |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
Just to let you all know, after running most of last winter with no FBH as it had packed in, the indie ran loads of tests on it, and it just wouldnt run, the other morning it fired up, no drama, chucked smoke out for a few minutes and then cleared. it has worked ever since. So im warmer quicker, plus ive saved a grand by not buying a new one |
MBaker Member Since: 16 Nov 2013 Location: Staffordshire Posts: 24 ![]() ![]() ![]() |
Hi Rob,
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
DL Link sent |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Get yourself a Ctek - I now have one with an adapter from Martin plugged in caravan electric socket as I sometimes leave RRS in garage for a while ![]() I see Lr now sell them as an accessory on the new RRS website - is that an omen ![]() Still hoping for a S2 one day! |
It's alive!!!
Good to see another FBH lives. Well done |
jpvd Member Since: 30 Sep 2023 Location: yorkshire Posts: 27 ![]() ![]() |
Hi all .i know this is an old thread, but i am having the same issue.
Ok..quick update...i checked fuse 28 and it was blown. So i inserted a new fuse, the fbh powered on, ran, then stopped and it smelt of burning - little smoke coming from the intake air pipe on the fbh. Fuse had popped again.
Doesn't cost anything to take it out and clean it,,, not sure if a choked combustion chamber would cause a fuse to blow,, but separate the two halves take out the burner tube and see what the chamber is like. Would be worth checking the water pump and the wiring harness to the heater,,, might possibly be the circuit board that controls the fan etc.
Thanks for the info...
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5027 ![]() ![]() ![]() |
Iβm thinking water pump if itβs not been run for ages. |
Thanks andy....that could have burnt out...problem is if it has can tou buy just that part or would i only be able to buy the whole fbh? There are loads on ebay, which aren't that expensive so i am tempted to just swap it all out.
The coolant pump is under the FBH
You can buy quite a few individual parts,,, some parts you cannot get,,, and some are stupid money. The fuel pump delivers a metered amount of fuel and is buried somewhere in the depths of time,,,, this is where the software program is invaluable. You can function test most things without even having to find them. 2010 RRS, TDV8
