Home > My Range Rover Sport > Another 1st time RRS owner |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Your excellent work on behalf of your RRS is making me feel a bit shameful. Today, the only things I did were change a number plate bulb and free off the nearside bonnet catch so it would shut properly. 5 minutes each.
Wed Nov 22 2023 10:08pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4990 |
Carry your iid with you. When you get the issue look at live values for The one with a small distance
Wed Nov 22 2023 10:40pm |
I don't have an IID. I used to have one but when I bought the SDV6 I couldn't get the IID to talk to it even though Gap told me directly that it should work. So I gave the IID to the chap who bought the TDV8. 2012 SDV6 - it's missing a couple of cylinders
Wed Nov 22 2023 11:14pm |
MHSPORT08 Member Since: 13 Nov 2023 Location: South East Posts: 38 |
If it inspires others to get a few jobs done that’s great
Thu Nov 23 2023 12:42am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
I second RRSTDV8s thoughts on your excellent work ethic MHSPORT08. Puts me to shame as well.
Thu Nov 23 2023 9:00am |
Couple more jobs done.
Fri Nov 24 2023 8:23pm |
Managed to get back in there today and look at the N/S sensor.
Sun Nov 26 2023 4:08pm |
I’m surprised that is the only fault code. Look again on other modules.
Sun Nov 26 2023 4:53pm |
Thanks Andy, I will take another look for codes |
Sun Nov 26 2023 7:06pm |
Bear in mind that the suspension system doesn't deal in absolute ride height numbers. The numbers it holds aren't the "ride height" but just a figure so that the system knows how much each sensor is moving. If the diagnostic system doesn't understand that, it will show figures that aren't correct.
Sun Nov 26 2023 11:55pm |
I did some further exploration with fault codes and came up with issues on
Tue Nov 28 2023 12:59pm |
Check your air tank is all I can say
Tue Nov 28 2023 3:43pm |
I think that may have been leaking a while |
Tue Nov 28 2023 6:40pm |
That'll be why the compressor was recently changed then. It will have been working flat out, poor thing. 2012 SDV6 - it's missing a couple of cylinders
Tue Nov 28 2023 8:59pm |
