![]() | Home > My Range Rover Sport > Another 1st time RRS owner |
Your excellent work on behalf of your RRS is making me feel a bit shameful. Today, the only things I did were change a number plate bulb and free off the nearside bonnet catch so it would shut properly. 5 minutes each. |
Carry your iid with you. When you get the issue look at live values for The one with a small distance
I don't have an IID. I used to have one but when I bought the SDV6 I couldn't get the IID to talk to it even though Gap told me directly that it should work. So I gave the IID to the chap who bought the TDV8. 2012 SDV6 - it's missing a couple of cylinders
MHSPORT08 Member Since: 13 Nov 2023 Location: South East Posts: 38 ![]() ![]() ![]() |
If it inspires others to get a few jobs done that’s great |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I second RRSTDV8s thoughts on your excellent work ethic MHSPORT08. Puts me to shame as well.
Couple more jobs done.
Managed to get back in there today and look at the N/S sensor.
I’m surprised that is the only fault code. Look again on other modules.
Thanks Andy, I will take another look for codes |
Bear in mind that the suspension system doesn't deal in absolute ride height numbers. The numbers it holds aren't the "ride height" but just a figure so that the system knows how much each sensor is moving. If the diagnostic system doesn't understand that, it will show figures that aren't correct.
I did some further exploration with fault codes and came up with issues on
Check your air tank is all I can say
I think that may have been leaking a while |
That'll be why the compressor was recently changed then. It will have been working flat out, poor thing. 2012 SDV6 - it's missing a couple of cylinders
