Home > General > Rear discs and pads advice |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
Sounds like a job well done. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Oct 11 2023 2:53pm |
Go through the adjustment procedure again and make sure everything is where it belongs. Screeching means it’s getting near the end of the shaft. The later screech is the brake applying more pressure since it’s not tight enough.
Wed Nov 01 2023 3:44am |
kttlaweb Member Since: 08 Aug 2016 Location: Derbyshire Posts: 16 |
Thanks for coming back to me so swiftly...
Wed Nov 01 2023 10:04am |
Need to look at the EPB we have at the shop. Seem to remember a little more grease on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Nov 02 2023 2:54pm |
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 95 |
Morning all, I'm needing mine doing now too. Ranf a local indy and they wanted..... Ready for this....
Tue Nov 28 2023 8:30am |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 163 |
Eh up ,
Tue Nov 28 2023 2:28pm |
Yes, your spot on. I've got the brake Bible all ready. Just wish I had a big enough garage to get it done. I no great rush I suppose. |
Tue Nov 28 2023 2:59pm |
Think I read a guy in the states was quoted $3,500 by a dealer for front and rear brakes on an L405 (not the disc/drum rear setup we have).
Tue Nov 28 2023 3:44pm |
Nah, just the shoes. I changed the pads and discs about 14 months ago and only travelled 3k in that time. E brake may just want cleaning up and adjusted. |
Tue Nov 28 2023 3:59pm |
A clean and adjust would be fairly easy to do and realistically all it needs (unless a shoe lever is seized or other such calamity). Is the parking brake making noise when you set it? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Nov 29 2023 3:20pm |
Yeah occasionally. I've bought the shoes and fitting kit etc. It creeps sometimes aswell so I suspect the arm. |
Wed Nov 29 2023 4:05pm |
If it’s squealing/creaking when you set it, stop using the parking brake till you get it addressed. Otherwise your future post will be about finding the emergency release which probably won’t work and then about cutting the cables to get it mobile. Then about how hard is it to rebuild/replace the EPB module.
Wed Nov 29 2023 8:30pm |
Thanks for the info, hopefully it won't get that bad.!
Wed Nov 29 2023 8:34pm |
