Home > Technical > In car heater issue
RRS23
United Kingdom 2010 Range Rover Sport 3.0 TDV6 S Java Black
In car heater issue
Hello people hoping someone here can shed some light on my issue
I have a 2010 stormer RRS and last night I noticed the fan blower in the car didn’t get very hot. I also noticed that the passenger right hand blower was just blowing cold air. The drivers left hand blower was blowing warm but not very hot. Anyone here lead me in the right direction what could be the issue please??
Post #637409 Sat Nov 18 2023 6:43pm
First try turning the temperature settings up to nearly maximum, to rule any control issues out.
A common problem on the older models in the heater matrix getting blocked up, and resulting in the passenger side (RHD) being cold.
Best to replace it, and flushing rarely works
Post #637412 Sun Nov 19 2023 9:46am
RRS23
Thanks Andy for the reply. I have turned the temp controls to full and still have the issue. Is replacing a big/expensive fix??
Post #637413 Sun Nov 19 2023 9:51am
It depends if there are joints inside to make things easy. If no joints, the dash has to come out.
The joints would be down by the pedals.
Some info and pics here:
https://www.rrsport.co.uk/forum/topic42040...ter+matrix
Post #637417 Sun Nov 19 2023 10:57am
RRS23
Thank you, my Range Rover sport is 2010 facelift model so are the instructions the same as the one in that thread you linked to.
Post #637420 Sun Nov 19 2023 12:13pm
very similar.
My worry is that they did away with the joints inside (meaning dash out job). So you need to see if you have joints before doing anything
Post #637426 Sun Nov 19 2023 1:51pm
