![]() | Home > Maintenance & Modifications > Split tailgate button on keyfob |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
From memory, it's a programmable button and each of the keys can be separately programmed, so are you sure you're using the same key each time? 2012 SDV6 - it's missing a couple of cylinders
mark8815 Member Since: 12 Nov 2023 Location: West Yorkshire Posts: 22 ![]() ![]() ![]() |
Yes 100% the same key every time. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
ensure car unlocked
Will go and give that a try now. Thankyou |
That kind of worked, the buttons on my upper tailgate must be broken, as I’ve managed to get the Land Rover button to unlock the lower tailgate. I think I remember reading that the upper was a known fault. Not to worry, atleast I know now. Thanks for your help |
I think Ford tailgate buttons fit off eBay (focus?) but you need to use your old connector. (Join wires) |
If it helps for the handle.
