Home > Maintenance & Modifications > Split tailgate button on keyfob
mark8815
United Kingdom 2005 Range Rover Sport TDV6 SE Rimini Red
New member/owner so go easy!
The button on the key fob which should unlock the upper half of the tailgate just turns the headlights on and off….. I’ve had the car a month and it did actually used to open the tailgate, any ideas why it’s changed?
Thankyou
Post #637218 Sun Nov 12 2023 2:41pm
From memory, it's a programmable button and each of the keys can be separately programmed, so are you sure you're using the same key each time? 2012 SDV6 - it's missing a couple of cylinders
Post #637219 Sun Nov 12 2023 3:21pm
mark8815
Yes 100% the same key every time.
Post #637220 Sun Nov 12 2023 3:46pm
ensure car unlocked
go to the rear off car
hold the LR button down on the keyfob, and while doing that press the upper release button on tailgate.
That should reprogram that key Mods: FaceLift/D4 Sat Nav Display and reverse camera. BT. Remote FBH. Parking light switch position. Rear reading light activated by doors.
Post #637222 Sun Nov 12 2023 3:58pm
mark8815
Will go and give that a try now. Thankyou
Post #637223 Sun Nov 12 2023 4:01pm
mark8815
That kind of worked, the buttons on my upper tailgate must be broken, as I’ve managed to get the Land Rover button to unlock the lower tailgate. I think I remember reading that the upper was a known fault. Not to worry, atleast I know now. Thanks for your help
Post #637224 Sun Nov 12 2023 4:05pm
I think Ford tailgate buttons fit off eBay (focus?) but you need to use your old connector. (Join wires)
Post #637226 Sun Nov 12 2023 5:06pm
Stevepd
If it helps for the handle.
https://www.rrsport.co.uk/forum/topic61504.html 2006 2.7 TDV6 HSE in Cairns Blue.
Post #637227 Sun Nov 12 2023 5:06pm
