Home > General (L494) > Cupholder problem!
jamesgarbett
Cupholder problem!
First world problem but does anyone have a photo of the inside of the cupholders near the gear lever?
Had our car valeted and now the cupholder "inserts" come out easily with the cup attached
Suspect the vacuum has removed something which holds them in but i can't recall what it is
Thanks
Post #635554 Mon Sep 04 2023 4:22pm
NoExpert
They probably removed that thing called friction. Likely they removed them and wiped everything down inside so now the liners slip out as well as grabbing cups better. I wipe the outside of the liners and inside of the holders with clean water and cloth so they stick to each other better. Works 90% of the time. Some cups/bottles just really stick in them. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635558 Mon Sep 04 2023 7:16pm
Clean the bottom and bit of 3m double sided tape or a bit of velcro job sorted.
Post #635566 Tue Sep 05 2023 12:38am
