![]() | Home > General (L494) > 2014 - L494 - ELECTRIC ISSUES |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 154 ![]() ![]() ![]() |
As DM has said, pretty sure it will be the earthing point under the n/s/f wheel arch liner snapped off due to galvanic corrosion. Had the o/s/f go on mine, replaced it with the LR approved repair stud & checked the n/s and it literally fell off in my hand |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 ![]() ![]() |
As Mike has posted , very common and your issues are the same as I had on that side ![]() |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
Posted this earlier in the month:
Took it to a local independent LR specialist on Monday after not being able to lock the car for two weeks. Car behaved perfectly when there, and has been fine ever since. When I checked for a fault code earlier in the month there were three "High speed CAN communication bus" intermittent errors (U0001-87; U0011-87; U0001-82) and a historic "Control module microprocessor B" (U1A4B-47) error, along with others. Any thoughts on this - sounds like a similar earth fault, but no idea where this would be to check. ![]() |
Same issue |
BenMurray Member Since: 30 Oct 2021 Location: UK Posts: 7 ![]() ![]() ![]() |
Fixed, 20 minute job!
