Home > Technical > EPB C1A00-4B system over temp |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 483 |
Something is causing it to draw too much current. Could be the motor is dirty or dying. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Fri Jun 16 2023 8:10am |
Bigsmithy2 Member Since: 16 Jun 2023 Location: Scotland Posts: 7 |
Could that be the case the moment the ignition is turned on without energising the motor? |
Fri Jun 16 2023 11:24am |
Yes. It tests the circuit and if the draw is too high it faults. Replaced one recently due to this issue. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sat Jun 17 2023 9:45pm |
Makes sense, I’m away with work tomorrow but will be back on the 26th, I’ll strip motor investigate and report back accordingly. 👌 |
Sat Jun 17 2023 10:11pm |
Well changed the motor for new with zero change to fault, starting to get on my last nerve this handbrake. Just need it to work once for the MOT.
Sat Jul 01 2023 3:29pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
If it logs that code even without applying the switch, there is a fault inside the module
Sat Jul 01 2023 3:55pm |
Any recommendations on replacement modules? Obviously some mentally priced ones out there but also some cheeper ones on eBay? |
Sat Jul 01 2023 4:41pm |
The cheap ones are Chinese . They don't last
Sat Jul 01 2023 4:45pm |
Aye you are correct, went down the road with a Chinese air pump!! Didn’t last long!! |
Sat Jul 01 2023 4:55pm |
There's your answer
Sat Jul 01 2023 7:12pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
That's how China makes its money. Buy cheap, buy once, buy twice, buy thrice, buy..........xxx times. |
Thu Jul 13 2023 2:50am |
