![]() | Home > Technical > EPB C1A00-4B system over temp |
Something is causing it to draw too much current. Could be the motor is dirty or dying. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Bigsmithy2 Member Since: 16 Jun 2023 Location: Scotland Posts: 7 ![]() ![]() ![]() |
Could that be the case the moment the ignition is turned on without energising the motor? |
Yes. It tests the circuit and if the draw is too high it faults. Replaced one recently due to this issue. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Makes sense, I’m away with work tomorrow but will be back on the 26th, I’ll strip motor investigate and report back accordingly. 👌 |
Well changed the motor for new with zero change to fault, starting to get on my last nerve this handbrake. Just need it to work once for the MOT.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4460 ![]() ![]() ![]() |
If it logs that code even without applying the switch, there is a fault inside the module
Any recommendations on replacement modules? Obviously some mentally priced ones out there but also some cheeper ones on eBay? |
The cheap ones are Chinese |
Aye you are correct, went down the road with a Chinese air pump!! Didn’t last long!! |
There's your answer |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 139 ![]() ![]() |
That's how China makes its money. Buy cheap, buy once, buy twice, buy thrice, buy..........xxx times. |
