![]() | Home > Technical > Play in steering wheel |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
no-one? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
Wheel bearing? 2012 SDV6 - it's missing a couple of cylinders
Didnt think of that as I havent any of the normal wheel bearing suspicions. |
Could it be play in the rack, especially if big wheels have been fitted at some point. The indie I use has said so much as to cars being blinged at some point in their ownership. 2006 2.7 TDV6 HSE in Cairns Blue. |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
I'd check for play in the lower steering shaft.
All sorted. New lower steering shaft. All nice and snug |
Funny that. I've recently had the lower shaft replaced (found as part of another issue) and the steering feels much better. |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
Sorry dont follow this ..you want someone in the car to rock the steering while you get underneath and feel for play....just like they do in the MOT Always listen to old people or when they die you will live on in ignorance.
