![]() | Home > General (L494) > HELP Please! - L494 Front Suspension Noise? |
RobF Member Since: 11 Oct 2013 Location: Suffolk Posts: 56 ![]() ![]() |
The good news is, you're not alone. Mine is a 16MY and I've noticed this develop recently and as you say, it's similar to the ARB problem that used to plague my '09 D3.
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
I have this too.
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 ![]() ![]() |
i am also having this now, started around a 6 months ago, get a knocking sound from front or back but not all the time so reproducing is hard. Generally seems to come when road has uneven surface and generally while turning rather then for pot holes.
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1675 ![]() ![]() ![]() |
Noticed some knocking last week, then realized that the car was in auto terrain (rare for me), then realized that in auto if the temperature is low the rear diff will partially lock on pulling away, then decided the knock was this.
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Having never driven another L494 I have nothing to compare with. So the question is can anybody tell me if I should expect to hear any knocking noises at all from the L494 front suspension??
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 ![]() ![]() |
Hi Guys sorry i know this is an old post but did anybody get to the bottom of this noise? I also have this annoying noise. I only hear it when im going over uneven roads at slow speeds, almost sounds as if something is bottoming out?
rickshaw Member Since: 03 Jul 2007 Location: West Yorkshire Posts: 195 ![]() ![]() ![]() |
I submitted this post originally. My dealer thought it was roll bar bushes (which was a surprise on a brand new car!). However this did not solve the problem. The car was then in the dealers for 5 weeks and despite involvement from Land Rover technical they were unable to solve the issue...... In the end I rejected the car and the replacement (when it eventually arrived) has been good - to date. |
yeah you do right rejecting it with a brand new car. I think i will just start with the roll bar bushes and go from there. Its hard to get someone else to listen out for the noise as it does not happen all the time. My wife misses it every time. |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 263 ![]() ![]() |
Apologies for resurrecting an old thread, anyway here goes.
Rangespbru Member Since: 18 May 2023 Location: Fife Posts: 2 ![]() ![]() |
Just bought myself a L494 with 61000 miles on the clock first of the new shape. Had a clunking coming from drivers front suspension going over speed bumps. Has the lower suspension arms and D bushes changed but still clunking. Doesn’t do it every day and even though the dealer admits they can hear it on a road test they can’t replicate the clunk on the ramps and as such don’t know what is causing it. Could be the ARB bushes straight arms, upper suspension arms or air suspension. Anybody get there clunking sorted as it’s driving me mad😡 |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 272 ![]() |
Just putting my 2 pence out here, Ive had some squeaking on the front going over small bumps at low speeds, no knocking.
Thanks for that information. I was going to gave the ARB links disconnected to see if the noise stops but I’ll try putting it in dynamic mode for a few days first. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Front arm bushes split, and give a vagueness and a knock when worn. Relatively cheap to replace
Rear arms on the front end dust covers split, water gets in and wears the ball joints, and bushes wear too. Ball joints cannot be replaced separately, so not a cheap job to replace And as said, ARB bushes can knock too. If you can move the roll bar from side to side with relative ease, these will most likely be the cause of the knock. In my experience, they tend to last around 50-60k miles... These were all done on a 2016 L405 with 62k miles, and passed an MOT with no advisories only 3 months ago ![]() |
Good to know that Mikey thank you |
