Home > General (L494) > HELP Please! - L494 Front Suspension Noise? |
RobF Member Since: 11 Oct 2013 Location: Suffolk Posts: 56 |
The good news is, you're not alone. Mine is a 16MY and I've noticed this develop recently and as you say, it's similar to the ARB problem that used to plague my '09 D3.
Tue Mar 06 2018 9:42am |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
I have this too.
Tue Mar 06 2018 12:12pm |
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 |
i am also having this now, started around a 6 months ago, get a knocking sound from front or back but not all the time so reproducing is hard. Generally seems to come when road has uneven surface and generally while turning rather then for pot holes.
Tue Mar 06 2018 7:23pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
Noticed some knocking last week, then realized that the car was in auto terrain (rare for me), then realized that in auto if the temperature is low the rear diff will partially lock on pulling away, then decided the knock was this.
Tue Mar 06 2018 7:52pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
Having never driven another L494 I have nothing to compare with. So the question is can anybody tell me if I should expect to hear any knocking noises at all from the L494 front suspension??
Tue Mar 06 2018 8:51pm |
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 |
Hi Guys sorry i know this is an old post but did anybody get to the bottom of this noise? I also have this annoying noise. I only hear it when im going over uneven roads at slow speeds, almost sounds as if something is bottoming out?
Sat Feb 29 2020 3:58am |
rickshaw Member Since: 03 Jul 2007 Location: West Yorkshire Posts: 195 |
I submitted this post originally. My dealer thought it was roll bar bushes (which was a surprise on a brand new car!). However this did not solve the problem. The car was then in the dealers for 5 weeks and despite involvement from Land Rover technical they were unable to solve the issue...... In the end I rejected the car and the replacement (when it eventually arrived) has been good - to date. |
Sat Feb 29 2020 8:48am |
yeah you do right rejecting it with a brand new car. I think i will just start with the roll bar bushes and go from there. Its hard to get someone else to listen out for the noise as it does not happen all the time. My wife misses it every time. |
Sun Mar 01 2020 3:35am |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 |
Apologies for resurrecting an old thread, anyway here goes.
Tue Jul 19 2022 2:20pm |
Rangespbru Member Since: 18 May 2023 Location: Fife Posts: 2 |
Just bought myself a L494 with 61000 miles on the clock first of the new shape. Had a clunking coming from drivers front suspension going over speed bumps. Has the lower suspension arms and D bushes changed but still clunking. Doesn’t do it every day and even though the dealer admits they can hear it on a road test they can’t replicate the clunk on the ramps and as such don’t know what is causing it. Could be the ARB bushes straight arms, upper suspension arms or air suspension. Anybody get there clunking sorted as it’s driving me mad😡 |
Thu May 18 2023 10:50am |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 248 |
Just putting my 2 pence out here, Ive had some squeaking on the front going over small bumps at low speeds, no knocking.
Fri May 19 2023 9:56am |
Thanks for that information. I was going to gave the ARB links disconnected to see if the noise stops but I’ll try putting it in dynamic mode for a few days first. |
Sat May 20 2023 12:26pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
Sat May 20 2023 12:46pm |
Good to know that Mikey thank you - can you replace the front/rear bushes on axle stands? Or is there not enough room to get hold of everything? |
Sun May 21 2023 6:20pm |
