![]() | Home > Technical > Turbocharger turbine inlet valve control / sensor circuit |
pomistea Member Since: 03 Jun 2021 Location: Dublin Posts: 43 ![]() ![]() ![]() |
I have two questions. Please remember I don't pretend to know much about this, at all...
Klingerl Member Since: 23 May 2021 Location: Queensland Posts: 5 ![]() ![]() ![]() |
the other reason that may be happening is a crack in the plenum cover
Raysunners Member Since: 20 Sep 2021 Location: Liverpool Posts: 14 ![]() ![]() ![]() |
I had this on mine was a simple fix, follow the vacuum pipes on drivers side to back of engine, there is a Y joint in pipe, mine was broken, found out when I tried to pull apart to test vacuum and it fell apart, replaced with a new joint fixed instantly! Hope you have the same luck |
Thanks for the replies.
Sounds like they've left a vacuum pipe off
Thanks @Disco_mikey.
Sorry I don't have any pictures, the joint was right at the back by the vacuum pump, there are two pipes coming off the pump, one goes to the brake servo and the other has the joint in going across to the other side of the engine |
I've a 3.0 in for belts on Tuesday. If its not sorted by then, I'll take some pics of the common troublesome points |
Wow, that would be great. Thank you |
