Home > Technical > Turbocharger turbine inlet valve control / sensor circuit |
pomistea Member Since: 03 Jun 2021 Location: Dublin Posts: 43 |
I have two questions. Please remember I don't pretend to know much about this, at all...
Sat Apr 15 2023 5:32pm |
Klingerl Member Since: 23 May 2021 Location: Queensland Posts: 5 |
the other reason that may be happening is a crack in the plenum cover
Sun Apr 16 2023 9:43am |
Raysunners Member Since: 20 Sep 2021 Location: Liverpool Posts: 14 |
I had this on mine was a simple fix, follow the vacuum pipes on drivers side to back of engine, there is a Y joint in pipe, mine was broken, found out when I tried to pull apart to test vacuum and it fell apart, replaced with a new joint fixed instantly! Hope you have the same luck |
Sun Apr 16 2023 9:59am |
Thanks for the replies.
Sun Apr 16 2023 10:11am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Sounds like they've left a vacuum pipe off
Sun Apr 16 2023 11:57am |
Thanks @Disco_mikey.
Sun Apr 16 2023 3:42pm |
Sorry I don't have any pictures, the joint was right at the back by the vacuum pump, there are two pipes coming off the pump, one goes to the brake servo and the other has the joint in going across to the other side of the engine |
Sun Apr 16 2023 5:21pm |
I've a 3.0 in for belts on Tuesday. If its not sorted by then, I'll take some pics of the common troublesome points |
Sun Apr 16 2023 5:41pm |
Wow, that would be great. Thank you |
Sun Apr 16 2023 5:45pm |
