Home > Maintenance & Modifications > Following my service the garage reported these advisories… |
Mon Jan 23 2023 8:04pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 342 |
Wow that was an expensive service |
Mon Jan 23 2023 9:10pm |
AIJ 615 Member Since: 19 Sep 2022 Location: Tamworth Posts: 119 |
You think ?
Mon Jan 23 2023 11:07pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Little curious on that one as well, as L/R specifically say the filler plugs on the transfer box and diffs are not level plugs, if changing the oils you fill with a specific measured amount of oil, unless there is a leak how did they determine the levels were low and possibly need topping up. Cheers Col |
Tue Jan 24 2023 12:57am |
So the LR specialist garage have quoted me the following to get some of the advisories from the recent service I had done.
Sat Jan 28 2023 6:48pm |
Sat Jan 28 2023 8:25pm |
Cheers for this, I will ask for more specifics detail relating to this. I assume for that price it would be full arms but again need them to reassure me of this
Sat Jan 28 2023 8:31pm |
I'm so glad I do my own repairs seems even the indies are over charging for repairs now days. I did both front lower control arms plus an inner cv boot on 1 side for less than £165 in parts on my drive. OK on our D3 but basically the same job as its the same parts. Soon todo o/s front lower on my rrs sc.
Sat Jan 28 2023 11:38pm |
So yeah as advised by you good folk I’d gone back to the garage and asked what exactly was I getting for the price quoted and the Response was this ,
Mon Jan 30 2023 11:16am |
A1GSS Member Since: 16 Sep 2011 Location: Saffron Walden, Essex, UK Posts: 152 |
I was recently quoted £280 parts (ex vat) plus 3 hours labour to change both lower fronts (local Indie, non-LR but OEM parts). So it doesn't seem out of whack.
Mon Jan 30 2023 12:28pm |
I know they have to make money but I'm sure I did both my front lower arms plus inner cv boot in less time than that on the floor. It's much easier on a ramp .
Mon Jan 30 2023 1:18pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Under an hour? I'm going to assume they are a garage in "not Scotland" |
Mon Jan 30 2023 8:30pm |
I really would like to see someone replace a front lower arm in under a hour, if the main pivot bolts are rusted solid in the bushes and they have to cut them out with a hacksaw or reciprocal saw. Sometimes you may be lucky and they are not seized other times not so especially on older vehicles, which is why it can take a lot longer.
Mon Jan 30 2023 8:31pm |
I got lucky with mine, nothing siezed I'm hoping I get lucky again when I do our new to us D3cand my off side on the rrs. What's the chances? Slim I know. |
Mon Jan 30 2023 8:34pm |
